weatherXML changes for DarkSky
This is a sticky topic.
  • Does anyone know if DarkSky provides Last Years High/Low temp? I've got the devices checked in the devices page but the value in HS web UI hasn't populated for the last several days.
    HS3 3.0.0.500 &HSTouch Designer 3.0.71 with 782 Devices, 479 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.252
    • They are part of the values that will only update once a day. Go to the Locations page and look for the Daily Section. You have the option to select Last Year Temps and/or Moon Phases. Next go to the Schedules page and make sure that you have the Daily Schedule activated.
      Jeff Farmer
      HS 3, HSPhone
      • Originally posted by CFGuy View Post
        Thank you! I had the daily schedule setup to run everyday, I just missed the check mark next to the “Last Year Temperature” under the Daily Setup.
        Plugin's:
        • The idea with the checkboxes is it will allow me to add more items under the daily section and allow you to pick and choose which ones you want to use. It will also allow a way to get an any extra info needed to get that particular data. Ex. If you were using NOAA as the condtion and forecast provider but wanted to get the Last Year data as well, there would be an API, Lat and Lon textbox so you could enter the info for DarkSky.
          Jeff Farmer
          HS 3, HSPhone
          • Jeff,
            Im currently running .7
            I'm still getting these errors whenever I access the Current weather page (/weatherXML?page=1) set for NOAA
            Apr-18 10:33:33 AM weatherXML Error Requested value '
            DeviceNightIconNameVal0' was not found.
            Not seeing anything wrong with the page as far as I can tell.
            Also getting a different error every time the NOAA current forecast is run
            Apr-18 10:30:01 AM weatherXML Error convertTempValues: Conversion from string "" to type 'Double' is not valid.
            Looks like Barometer and Barometer Direction haven't update for a week and Visibility hasn't updated in several days and Wind Gust is a question mark.
Name:	conditions current.png
            • Something that I did was to go through each of my weather devices and any that hadn't updated today I removed. I then went in to the device settings and toggled the check boxes for each of the devices. That cleared all of my errors (this was back a week or so ago when this fun all started.
              HomeSeer Version: HS3 Pro Edition
              Operating System: Microsoft Windows 10 Pro
              Processor Type and Speed: i7 - 3.26 GHz
              Total Physical Memory: 16Gig
              Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
              • Originally posted by prsmith777 View Post
                Jeff,
                Mentioning that it is happening when you accessed the current weather page was the clue that I needed.
                Got it fixed and it will be available in the next release.
                Jeff Farmer
                HS 3, HSPhone
                  Jeff,
                  Click image for larger version  Name:	current.png Views:	1 Size:	124.5 KB ID:	1299705
                  Click image for larger version  Name:	conditions current.png Views:	1 Size:	388.7 KB ID:	1299706
                  With error that are happening each time a schedule runs, I really need a logoutput to be able to see what it going on in the background.
                  Jeff Farmer
                  HS 3, HSPhone
                    Strange. I can't seem to reproduce this error now. When it pops up again, I will send a logoutput file.
                    • I do notice that the NOAA barometer and barometer devices are not changing or updating. They have been stuck at the same level for over a week.
                      I thought I'd try to delete the devices and recreate them. So I did that this morning and I'm not seeing them correlate with the NOAA station I am using. For instance the NOAA barometer reading is 30.22 yet my device is still saying 30 and has said 30 for over a week.
                        I've seen this error come and go over the last few days. It seems to happen each run for 4 or 5 runs then stops for 12 hours or so. I pull DS current every 30 minutes. So my guess is something in the DS feed is missing or malformed. I'll try to capture a log and the DS feed if it happens again.
                        Last edited by drparker151; April 19th, 2019, 11:20 AM. Reason: changed NOAA to DarkSky
                        • Why is it that even though I'm using Darksky, that the daily schedule is referring to Weather Underground? I'd like to get Max high/Min low temps for a given day.
                          • Originally posted by langenet View Post
                            The Daily Schedule only handles things that can be updated just once per day. New Moon, Full Moon, First Quarter, Last Quarter, The Today Last Year high and the Today Last Year Low. The message you are seeing about Weather Underground is for the Hourly Forecast. That has not been updated yet. If you are looking for the forecasted high and low temp values that would be in the forecast schedule. Go to the Devices page and select which of the forecast days you want the forecasted high and low values for.
                            Jeff Farmer
                            HS 3, HSPhone
                            • Jeff,
                              I managed to catch the error this morning and a few others. Here is the log file.
                              logOutput.txt
                              • I can see where the error is happening but couldn't tell which of the temp values was causing it. I've added some more logging and will have you make another log file when I release .7 to the HS Updater.
                                Jeff Farmer
                                HS 3, HSPhone
