weatherXML changes for DarkSky
  • #16
    Originally posted by CFGuy View Post
    Edit the icon device and go to the Status Graphics page. If there is no icon there you can add one. Make sure the image is in the Html/images/weatherXML/Condition/ directory. It should exactly match the text showing except the image will need a - instead of a space. The image needs to have the png extension.
    Thanks, but the generated value for device "Condition: Day" is -999, so how does one then create a list with different values? Or, how does one map weather condition strings to images if the "Status Graphics" tab in the device only allows for values?
    • #17
      I forgot to add this to the main post above. DarkSky does not provide icons. So if you have been using weatherXML for a while you probably have several icons from other providers. You can rename them to match thins list and they will be used. The night ones only work the Conditons devices. The rest work with both Conditions and Forecasts.
      Once I add the Hourly forecasts the nights ones should work for that.
      These last 3 are not used, but DarkSky said they might add them in the future
      Jeff Farmer
      HS 3, HSPhone
      • #18
        The plugin will add the correct icon (if it exists) and set the value when the device is next updated.
        The ability to add all the images at one time is on my to do list. An example is the Temperature devices. Those devices and the Moon Phase device have all the icons in the Status Graphics already. You can change the images to be what you want, just don't change the value for them.
        Jeff Farmer
        HS 3, HSPhone
        • #19
          Thanks. I was trying everything to get this to work, but to no avail. Finally got it to work by deleting the .json files in folder HomeSeer HS3>data>weatherXML. Then I went to schedules and ran them to recreate those files and... voila, each appropriate status graphic from the condition folder was now associated with the displayed device.
          • #20
            Just sent you a donation (to offset your night out at the movies the other day)
            • #21
              I'm sorry, but I'm still confused by images not working and I think I've done what everyone else has suggested. There are appropriately .png files in the Html/images/weatherXML/Condition directory. No errors or red lines in the log file. I tried deleting the json files as suggested, they are recreated but still no change. The forecast data is there and correct, but images aren't updating. I have a custom built HS Touch panel and it's showing nothing for Current, and the NOAA images for forecast. The WeatherXML User pages show the correct images.
              I have no icon showing for current condition, just the word clear.
              My Icon Image devices have the NOAA icons in them still.
Name:	Icon Image.png
              I have icons for clear-day and rain - but not happening.
              • #22
                right click on one of those NOAA images, paste the link into another browser page. make sure the image you want is in that location with that name. If on Linux, case matters. above you posted Condition and mine is all lower case?
                • #23
                  The file I want is in that folder, the image name/path though is for the NOAA icon of course. I can change the image to the one I want by editing the device, but shouldn't the PI be doing that for me automatically?
                  • #24
                    I manually edited the image for one device, but here's what I'm seeing. The Icon Name values are correct, but the icon's themselves are incorrect/not matching (apart from device 4574 which I edited to set to the 'correct' icon - rain.png
Name:	Icon and Icon Names.png
                    • #25
                      Currently, the image devices get changed each time the schedule runs. You need to make a copy of the NOAA image and change it's name to match the name in the Icon Name device. Rename the actual image as partly-cloudly-day.png. Then the next time the schedule runs it will put that image in the device to display it.
                      I do have on my to do list to make so anytime a new image name comes along it will get its own entry in the Status Graphics. At that point you can then change the images in the device.
                      Devices that you can currently do that with are Temperature. You can change the thermometer images as long as you don't change the values. And the moon devices can have their image changed.
                      Jeff Farmer
                      HS 3, HSPhone
                      • #26
                        Do not edit the device. Edit the name of the images in your condition folder to match what is being pulled from DarkSky.
                        The names they currently use for icon file names can be found here: https://darksky.net/dev/docs/faq
                        • #27
                          I shut down my HS3 system and did a Tar of the entire HomeSeer directory like I do every Sunday. Since rebooting I keep getting these errors every time it runs a forecast schedule. I tried to disable and reenable the weatherXML plugin to no avail.
                          2019-03-11 02:18:29.6646230 PM weatherXML Download Status: Success
                          2019-03-11 02:18:29.6647180 PM weatherXML wXMLValueSetRef: 3/11/2019 2:18:29 PM
                          2019-03-11 02:18:29.6702110 PM weatherXML importDSForecast
                          2019-03-11 02:18:29.6770030 PM weatherXML Data imported for DarkSky. Finish the process
                          2019-03-11 02:18:29.6771360 PM weatherXML Provider: Dark Sky, Set Days: 7, Actual Days: 8
                          2019-03-11 02:18:29.7047210 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7051680 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7055980 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7060420 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7064810 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7069370 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7073640 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7078220 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7082810 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7087430 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7092490 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7097170 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7101690 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7107000 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7111900 PM weatherXML Error ConvertValues Temp
                          2019-03-11 02:18:29.7116760 PM weatherXML Error ConvertValues Speed: Method 'System.String[].Set' not found.
                          2019-03-11 02:18:29.7132640 PM weatherXML Checking 3/11/2019 12:00:00 AM
                          2019-03-11 02:18:29.7138690 PM weatherXML Finished Checking Image for 3/11/2019 12:00:00 AM
                          2019-03-11 02:18:29.7141390 PM weatherXML Set the forecastDay
                          2019-03-11 02:18:29.7145830 PM weatherXML Set the Day abbreviation
                          2019-03-11 02:18:29.7147210 PM weatherXML Set the Night abbreviation
                          2019-03-11 02:18:29.7148620 PM weatherXML Date Format = 1
                          2019-03-11 02:18:29.7151540 PM weatherXML Set the Night condtion
                          • #28
                            Jeff, can you check what is being pulled from DS's servers for "Dark Sky Forecast 1." Both yesterday and today, I'm getting the nighttime forecast for what would be tomorrow's forecast, which also results in a corresponding nighttime icon. Forecast devices 2-7 all have daytime forecasts/icons.
                            thanks
                            • #29
                              I do have images with names that match those needed by DarkSky in the correct folder. Take a look at my screenshot for Icon Name 1 and the graphic shown for Icon Image 1 - the image being shown is not named rain.png. There is a rain.png file in the folder, and it's not that one. It's the one showing for Icon Image 0. that graphic is named rain.png.
                              • #30
                                look at the path in Status Graphics setting for each device are they exactly the same?
