weatherXML changes for DarkSky
  • #61
    Originally posted by CFGuy View Post
    I just posted a new version that should finally have all the "Round Units To" working correctly for both Conditions and Forecast values.
    Use the URL from the email.
    I will be unavailable for the next 3 hours but will check email when I get back.
    Thanks for the work you have put into this Jeff. The latest version corrected the rounding feature.
    • #62
      Originally posted by jpape View Post
      Sorry one last item, can you have the forecast status be capitalized. As an example, it currently shows as "partly cloudy day". Can you make it "Partly Coudy Day"?
      Judd
      You mean like this?
      This will be in the next release. It will upper case each of the words in the Condition text.
      Jeff Farmer
      HS 3, HSPhone
      • #63
        Working good here. I just have to change the icon file names but I think everything else is good.
        tks
        HSPro on a Supermicro Atom|Z-Net
        Elo touchscreen client, Android Phones and Tablets, Xbox One
        Global Cach/Ultra-GCIR | Etherrain | Jon00 | Sonos | Blue Iris | URC Whole Home Remotes | Philips Hue | Nest | Grandstream | Leviton | Aeon Labs | Cooper | Kwikset | Evolve | Envisalink/DSC | Amazon Alexa/IFTT
        • #64
          You mean like this?
          Yes exactly. Thanks for the quick turnaround.
          • #65
            Jeff, my subscription to World Weather has expired and for some reason the free version is not working, could I test the new plugin with the new API?
            Aldo
            • #66
              Aldo
              Read the first post in the Thread. Instructions at the bottom. Not sure if he is still adding beta testers.
              • #67
                Thank you, sometime so difficult to stay updated with so many posts.
                Sent from my SM-G935V using Tapatalk
                • #68
                  Do you have to select Dark sky in the forecast setup section also?
                  Hector
                  Win.2003 OS, HS3
                  MyTrigger,ACRF2,W800,Zwave
                  AP800,Honeywell Stat
                  • #69
                    I think he fixed the error and you can leave it at "Same as". However,
                    I do have mine set to DarkSky
                    • #70
                      Stuck with trying to setup WeatherXML using Dark Sky. Where do I insert my API key, Lat etc?
                      Thanks.
                      Don
                      • #71
                        You will need to go up to the top of the page and select DarkSky in the source dropdown. That will refresh the page so that you can enter the API, lat and long. Then in the forecast section, you will select DarkSky and set the tide usage to No. There is no more tide information available.
                        Jeff Farmer
                        HS 3, HSPhone
                        • #72
                          Ah ha! Thanks.
                          Don
                          • #73
                            If you want to use Dark Sky and want tide info you can get it using WorldTides here:
                            https://forums.homeseer.com/forum/de...tides?t=158143
                            • #74
                              anyone knows how to fix this? or is this going to be fixed in the next update? Click image for larger version
                              Hector
                              Win.2003 OS, HS3
                              • #75
                                look back through this thread. A list of the icon names was posted. DarkSky does not provide any icons. You can look in the HS/html/images/weatherXML/conditions directory. There should be icons left over from WU. Find some icons that match the condition of the DarkSky icon names. Things like rain.png, partyly-cloudy-day.png. Rename an existing icon for each posted icon name. The next time that the forecast schedule is run it will use the icons you rename. You must match the posted list exactly or you won't get icons.
                                Jeff Farmer
                                HS 3, HSPhone
