weatherXML changes for DarkSky
  • Here are my noaa and dark sky forecast devices:
Name:	noaa forecast.png
Name:	darksky forecast.png
    • I saw this as well and rolled back. Are you Linux? If so what version on Mono?
      I'm on Ubuntu 18.04 with Mono 5.18.1
      • Originally posted by drparker151 View Post
        No I'm on Windows 7
        • Ok, I asked because an earlier array error seemed to be on linux install only.
          • Also, the forecast devices for NOAA and DarkSky are not updating.
            • Are you changing who the forecast provider is, it won't pull from both at the same time.
                I did have them set to pull at the exact same time. I just changed it. But when I manually try to pull one forecast, I still am not getting anything.
                • Where there any changes after the last update?
                  Hector
                  Win.2003 OS, HS3
                  MyTrigger,ACRF2,W800,Zwave
                  AP800,Honeywell Stat
                  • Originally posted by Rotech View Post
                    I have made several fixes tonight. I will send it to the updater approval site tonight. Hopefully it will get approved early tomorrow.
                    I will not be around my computer tomorrow during the day. I won't be able to answer posts until the evening.
                    Jeff Farmer
                    HS 3, HSPhone
                    • It looks like the ability to replace images was not added to dark skys. Will this be added soon or should I look for a work a round for this?
                      Tony
                      HomeSeer Version: HS3 Pro Edition
                      Operating System: Microsoft Windows 10 Pro
                      Processor Type and Speed: i7 - 3.26 GHz
                      Total Physical Memory: 16Gig
                      Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
                      • Here are the names of the icons that DarkSky uses.
                        These last 3 are not used, but DarkSky said they might add them in the future
                        Use whichever icons you want to use and save them with the above names to the html/images/weatherXML/condition directory.
                        The next time the schedule runs it will use the images.
                        Jeff Farmer
                        HS 3, HSPhone
                        • I have the same errors as Prsmith777 lists in post #120.
                          • Same here...
                            Don
                            • Originally posted by grtaylor View Post
                              Jeff sent a new update in to fix this, hopefully HS posts it to the updater today.
                              • I just checked, the new update is posted, testing now.
