Jeff:
For some time I have been shamelessly using the HSTouch weather templates you provided, including the Current Weather screen with a button that passes some parameters obtained from script statements to a smaller "today's forecast" screen. Among those parameters is the current DATE via this script:
This worked fine with WU - however with DarkSky the DayDate0 value is now a date AND time value (I checked my weatherinfo.ini file just to make sure). The larger value takes up too much room for the space I have on the HSTouch screen. I'm sure I can figure out how to chop off the time - but just wondering if you intended to make this change to DayDate0...
Regards,
BBB
[$SCRIPT=&hs.GetINISetting("Forecast1","DayDate0","","weatherXML\weatherInfo.ini")]
Regards,
BBB
