New Plugin will not start...
    I just downloaded the latest WeatherXML plugin and when I try to start it, it says "Pending". I checked the log and found the following:
    Mar-31 23:13:37 Error A call was made to save a global variable (LogMessage) but that global variable has not been defined.
    Mar-31 23:13:37 Informational UltraLog3 HSPI capture variable "LogType" ready for use. See HomeSeer GetVar API for usage.
    Mar-31 23:13:37 Error A call was made to save a global variable (LogType) but there are none defined in the system.
    Mar-31 23:13:37 Error Starting plug-in exe process: The specified executable is not a valid application for this OS platform.
    I am still running XP on that machine. But, WeatherXML used to run on XP. Did something change?
    None of those are error messages created by weatherXML so I am not sure what to have you try. The red error would have the word weatherXML in it if the plugin generated it.
    Let's try this. Go to the Plugin Management page and click to make sure that weatherXML is not trying to start. Click the checkbox labeled Developer Mode and the click to start the plugin. See if it gives any messages. If not you can close the DOS window that opened. Uncheck the Developer Mode. In the directory HomeSeer HS3/config/weatherXML directory delete the 2 ini files. Move up 1 directory to HomeSeer HS3/config and delete the hspi_weatherXML.ini file. This will reset all the settings and the plugin should now start up from scratch.
    Jeff Farmer
    HS 3, HSPhone
      Thanks, I tried starting the plugin in dev mode, did not get a DOS window. Error in HS log was:
      Apr-01 11:19:31 Plug-In Finished initializing plug-in weatherXML
      Apr-01 11:19:31 Starting Plug-In weatherXML loaded in 15089 milliseconds
      Apr-01 11:19:16 Error Starting plug-in exe process: The specified executable is not a valid application for this OS platform.
      I also tried deleting the ini files, still getting the same error. I guess that it is an issue with my OS build. A few months ago I had a hard drive failure and had to rebuild the OS from the original XP install media, then update to SP3. Everything on the PC works better than before - except this PI doesn't work at all. I will have to dig deeper. Thanks for the help.
        Maybe the EXE file is corrupt. Did you try deleting the plugin and re-downloading it?
          Yes I did, a couple of times, but no change.
            I am having the same problem, downloaded it today
              The only thing I can think of is that I recently upgraded my editor to Visual Studio 2017 and changed the target version of dot net so that I could add more security to the code that downloads the data. Version 4.7.2 for dot net.
              Jeff Farmer
              HS 3, HSPhone
                4.0 is the latest that is supported on XP, so anyone on that OS will not be able to use it then.
                  Those using Windows XP wait for version 3.0.1.02. I submitted it to the HS updater today.
                  Jeff Farmer
                  HS 3, HSPhone
                    3.0.1.02 is now in the updater. You should be able to run it with windows xp. If you would give it a try and let me know, please.
                    Jeff Farmer
                    HS 3, HSPhone
                      Why does my currently installed version announce itself as 3.0.1.1?
                        It's there, downloaded and installed, all good at this point, have not set it up yet, but, will keep you posted. Thanks.
                          It appears to be working, but no data, just errors!
                          [quote]
                          Apr-03 18:01:00 weatherXML Download Status: Failure
                          Apr-03 18:01:00 weatherXML Error downloadFile: Dark Sky Forecast from: https://api.darksky.net/forecast/d17...utely&units=us, Also save copy as: Error: The requested security protocol is not supported.
                          Apr-03 18:01:00 weatherXML Forecast Source: ds
                            I'll look into this some more. Will try to send a fix to the updater soon.
                            Jeff Farmer
                            HS 3, HSPhone
