No condition ICONS
    No condition ICONS
    For some reason with the latest version I do not have any condition Icons.
    MESSAGE BOARD
    (copy/paste section below to message board posts)
    Current Date/Time: 4/7/2019 10:06:50 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.500
    Operating System: Microsoft Windows Embedded Standard - Work Station
    System Uptime: 5 Days 22 Hours 4 Minutes 42 Seconds
    IP Address: 192.168.1.215
    Number of Devices: 470
    Number of Events: 70
    Available Threads: 200
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed:
    In Virtual Machine: No MFG: shuttle inc.
    Enabled Plug-Ins
    3.3.2.0: APCUPSD
    3.0.19.0: BLLock
    3.0.0.56: EasyTrigger
    3.9.610.5: HSBuddy
    3.0.0.114: LutronCaseta
    3.0.6.9: SDJ-Health
    3.0.6681.34300: UltraCID3
    3.0.6644.26753: UltraLog3
    3.0.6922.16073: UltraM1G3
    3.0.5902.19061: UltraSMTP3
    3.0.1.4: weatherXML
    3.0.1.256: Z-Wave
    See the following, There is more info in the Sticky post at the top of the forum WeatherXML changes for Dark Sky .https://forums.homeseer.com/forum/we...es-for-darksky This comes from page 2 of that post.
    "I forgot to add this to the main post above. DarkSky does not provide icons. So if you have been using weatherXML for a while you probably have several icons from other providers. You can rename them to match thins list and they will be used. The night ones only work the Conditons devices. The rest work with both Conditions and Forecasts.
    Once I add the Hourly forecasts the nights ones should work for that.
    These last 3 are not used, but DarkSky said they might add them in the future
    Tornado.png"
    I went in to the directory specified, changed the names of the appropriate .png files to match the above and all is well.
    Hope that helps.
    Chuck
      Thank you I change a few and I now have images.
        I have changed the icons to match what is listed above:
Name:	WeatherXML Icons.png
        And the icons do not show up under my condition.
        Is there anything that i need to do to reset or get them pulling correctly?
        Jason
          Have you tried disabling the plugin and then the-enabling it?
          BBB
            Been there. Delete you browser image cache. Should work. Thx
              BBB and 123,
              I tried both of your suggestions and neither worked. Any other ideas?
                Did you refresh the forecasts ("schedules" tab)?
                  I did. It runs every 4 mins.
                    Are the images in the correct "production" folder; I see yours is named "Homeseer" (vs Homeseer HS3).
                    Try enabling Vertical/Horizontal forecast icons and validate if the newly created icons are populated in this folder.
                      I have a Zee homeseer. The path is in the image above.
                        I had to update my SD card and software. Here is an image of the folder with the correct files: Click image for larger version  Name:	WeatherXML Icons.png Views:	0 Size:	29.7 KB ID:	1356556
                        The Owner is now Root and i am still not getting an icon.
Name:	Homseer Weather.png
                        Jason
