Error importing data from Cumulus file with v3.0.1.4
  • Error importing data from Cumulus file with v3.0.1.4
    I just upgraded to version 3.0.1.4 and I'm suddenly getting a bunch of error as part of the Cumulus file import. Any idea what's going on or how to fix this?
    Apr-10 9:05:14 AM weatherXML Error deviceBarometer: Conversion from string "" to type 'Short' is not valid.
    Apr-10 9:05:14 AM weatherXML Error deviceBarometer: Conversion from string "" to type 'Double' is not valid.
    Apr-10 9:05:14 AM weatherXML Error buildWindString: Conversion from string "" to type 'Double' is not valid.
    Apr-10 9:05:14 AM weatherXML Error importCumulusFile Contents: 10/04/19 09:05:14 53.9 73 45.4 1.0 0.0 5 0.00 0.00 30.318 N 1 mph F in in 0.3 +0.006 0.19 15.76 0.00 72.5 42 53.9 +4.3 53.9 09:05 40.1 06:59 2.0 08:57 5.0 08:54 30.322 08:49 30.257 00:05 3.0.0 3038 4.0 53.9 54.2 0.0 0.003 443 360 0.00 1 1 0 N 1922 ft 52.3 2.2 384 1
    Apr-10 9:05:14 AM weatherXML Error importCumulusFile: Conversion from string "km/h" to type 'Double' is not valid.
    Apr-10 9:04:14 AM weatherXML Error deviceBarometer: Conversion from string "" to type 'Short' is not valid.
    Apr-10 9:04:14 AM weatherXML Error deviceBarometer: Conversion from string "" to type 'Double' is not valid.
    Apr-10 9:04:14 AM weatherXML Error buildWindString: Conversion from string "" to type 'Double' is not valid.
    Apr-10 9:04:14 AM weatherXML Error importCumulusFile Contents: 10/04/19 09:04:14 53.7 74 45.6 2.0 0.0 5 0.00 0.00 30.319 N 1 mph F in in 0.3 +0.006 0.19 15.76 0.00 72.5 42 53.7 +4.3 53.7 09:03 40.1 06:59 2.0 08:57 5.0 08:54 30.322 08:49 30.257 00:05 3.0.0 3038 5.0 53.7 54.1 0.0 0.003 441 357 0.00 1 1 0 N 1839 ft 51.5 2.2 380 1
    If you can go to the weatherXML settings page, and for logging level select "weatherXML log file". Then manually run the Conditions schedule.
    Go to the Debug Log page and click the button Save To File. The file will be saved in the HomeSeer HS3/data/weatherXML directory and named logOutput.txt.
    Email that file to me at jeff@myautomatedhome.net.
    That will be a big help and I can take a look to try to figure out why it has started happening.
    Jeff Farmer
    HS 3, HSPhone
      Log file sent. Thanks for your help.
        I have it fixed and will send it as part of 3.0.1.6 to the updater tomorrow.
        Jeff Farmer
        HS 3, HSPhone
          I saw that 3.0.1.5 got pushed out today, but still has the exact same error. Is 3.0.1.6 still the version that will have the fix?
            Yes. Your fix is part of 6. If you want to get it sooner go to the debug log page and click the button create updater file. Then go to the plugin management page and click update listing. Open up the list of plug-ins and find weatherXML. Stop weatherxml. Then select it and install it. Restart the plugin and confirm that you are on .6.
            Jeff Farmer
            HS 3, HSPhone
              That did the trick. Thanks!
                For those on linux the updater_overide.txt file has the O capitalized, need to change it to all lower case for HS3 to pick it up.
                  Fixed and will be ready in .7
                  Jeff Farmer
                  HS 3, HSPhone
                    The release notes thread will be updated again for each new version.
                    https://forums.homeseer.com/forum/we...-for-hs3/page4
                    Jeff Farmer
                    HS 3, HSPhone
