Strange values in weather devices
    After upgrading the plugin and migrating my old setup to DarkSky all WeatherXML values are messed up (see screenshot). Un-installing the plugin, remove all related devices and files (as far as i could find them) en re-install the plugin did not seem to make things beter so far. This is on win7.
    However, on my Linux system everything looks like expected, so no problem there.
    All tips are welcome...
    I am seeing similar values here. I am afraid this could be the return of dreadfull dot vs comma for decimals?
    Wim
    -- Wim
      w.vuyk hit it on the head. When I wrote the functions to convert from one unit to another, I forgot to add the code for regional decimal separator.
      So a comma instead of a dot would cause the conversion to fail.
      I tried to convince the rest of the world to convert to my way of thinking but that failed so I added the Regional check back in.
      If you go to the new page labeled Debug Log, you should see a button labeled Create Updater File. Must be on wxml version 3.0.1.5 or higher for the button.
      Clicking on that button will place an Updater Override file in the HS directory. You can then go to the updater page and click Update Listings.
      Open the Interface headings for weather. You will be able to download version 3.0.1.7.
      You can also wait for .6 to hit the normal updater. I submitted it on Friday and it should be approved in the next day or so.
      .6 fixed the issue you are seeing for all but percentages. .7 fixed that and one of the testers from France has confirmed that the values are back to normal. Even if they have a funny looking dot.
      Jeff Farmer
      HS 3, HSPhone
        Shame you did not succeed Things would be so much easier....
        Anyway. I can also confirm that installing 3.0.17 solved the problem. Thanks for the quick support.
