Replace Name
    Replace Name
    Hi,
    Is there the possibility of replacing the names of the days of the week in Italian in HSTouch? thank you
    I will add that to the next release. Here is how it will work. For users that don't have the Day Name devices created. You will go to the Devices page and enter any prepend or append text that you want to use. Then click the checkbox to add the device. As the device is created the Device Status Graphics tab will have 7 statuses added. 0 = Sunday, etc. The prepend and append will be added to the day name text. "prependtext Sunday appendtext"
    You can then go and edit the day name part of those statuses as the import will not change the text of the statuses. Each time an import runs, the only change will be that the Device Value will be set so the correct day is set for the device.
    If you already have existing day name devices, then will get a Sun through Sat Status added. You can then edit the status text to what you want it to say.
    Either way, you will end up with the text you want to use in HSTouch.
    I will update this thread when the version with this change is ready for testing.
    Jeff Farmer
    HS 3, HSPhone
      Ok Thanks
        3.0.1.7 was submitted to the HS updater this evening. Once its approved it will be available on the plugin management page. It will modify the Day Name devices to have Status Graphics Text entries for the days of the week. You can modify the text as you wish.
        Jeff Farmer
        HS 3, HSPhone
          ok thank you tonight I'll try
            With the update you solved my request. It works very well. Thank you
              Hello. I made the changes you indicated in "Status Graphics" but it seems that in "Advanced" the value does not change. So the days of the week never change. Thank you
                I have this fixed and will post a .8 version to the HS updater tomorrow.
                Jeff Farmer
                HS 3, HSPhone
                  Ok thank you
                    3.0.1.8 is now in the HS updater.
                    Jeff Farmer
                    HS 3, HSPhone
                      Ok just updated. I'll let you know. Thank you
                        Hi I noticed that unfortunately it is no longer possible to change the names of the days of the week. Is it still possible to have this chance? Thank you
