seeing error in log
    seeing error in log
    Haven't really checked mylog in a while. But when I did, I noticed these errors quite often, sometimes every 10 minutes:
    May-16 12:10:01 PM weatherXML Error convertTempValues: Conversion from string "" to type 'Double' is not valid.
    Was seeing them on 3.0.1.8 and updated to 3.0.1.9 with same errors.
    Let me know if you need a log file.
    Yes please.
    Jeff Farmer
    HS 3, HSPhone
      +1
        Please follow the instructions in this thread so that I can help you.
        https://forums.homeseer.com/forum/we...herxml-support
        Jeff Farmer
        HS 3, HSPhone
          moved up to 3.0.1.10 and am seeing a few different errors including
          May-26 5:01:01 PM weatherXML Error setForecastDataHST Icon Image: Index was outside the bounds of the array.
          and
          May-26 5:00:00 PM weatherXML Error downloadNOAAXML: Arithmetic operation resulted in an overflow.
          logout file attached
          logOutput.txt
            None of my NOAA Conditions devices have updated since moving to 3.0.1.10 on 5/26/19. Is there somewhere I can get 3.0.1.9 to revert back to until this is fixed?
              thanks, sent you an email with debug log
                I updated to .10 also and now my speak alerts stopped working. I basically have a alert trigger for my county and all alerts would speak over sonos.
                To further clarify, I get this error in the log (but I never tried the test button before as has worked for years):
                weatherXML Error Trigger test failed due to no script or speak/email message text setup.
                I never had anything in the text field before. I just had the alert text speak over sonos:---has anything changed in .10?
