Odd behavior of Forecast devices
    #16
    By any chance does this version deal w/ my issue?
    Don
      #17
      Looks like it fixed mine.
        #18
        No, but I was finally able to duplicate the error so I will work on it this weekend.
        Jeff Farmer
        HS 3, HSPhone
          #19
          The .17 version that went to the updater this morning fixes your error with the Legacy forecast day names.
          Jeff Farmer
          HS 3, HSPhone
            #20
            Thanks Jeff...
            Don
              #21
              I'm not seeing .16 (or .17) available in my "Installed Plug-ins" list yet. ...Should I?
                #22
                .17 Should be showing. I got the approval notice from the HS updater.
                Jeff Farmer
                HS 3, HSPhone
                  #23
                  On closer inspection, .17 is showing under "Additional interfaces", but under my "Installed Plug-ins" list the version is still .13 and the "Update" column says "N/A". (No update available).
                  I've tried restarting Homeseer, but no change. Is this a problem with Homeseer plugin update functionality?
                  Anyway, I installed .17 from the "Additional interfaces" list and am happy to report that everything seems to be working fine now! Thanks!
                  ...But this makes me wonder if there are other plugins that has newer versions that are not showing on the "Installed Plug-ins" list.
                    #24
                    Version .18 was approved this morning. I checked my Plugin Management page and in the Installed Plugins area it is showing .18 as available.
                    I really don't have any control over the Plugin Management page. I submit a new zip file to the Developers portal and when it is approved it shows up in Plugin Management.
                    Jeff Farmer
                    HS 3, HSPhone
                      #25
                      Thanks Jeff, will give it a try.
                      Don
