Is there a document that explains how to set up forecast images? It seemed to work by default with WU. After switching to DarkSky I cannot find devices that contain forecast images. Thank you.
Forecast Images
Click on the weatherXML menu button labeled Help. That will take you to a page with several pdfs. Click on the link for Quick Start. The last section in that pdf explains how to use icons with Dark Sky.--
Jeff Farmer
HS 3, HSPhone
I could use a bump in the right direction. I created weather icons. I loaded them in the specified directory. They now show up under the Current and Forecast tabs. I checked off devices to be created for images. But in HS3 Touch - I cannot find a device that properly shows those icons. I pretty much tried every available device without success. See screenshots.
The devices will be the Icon Image 0 to 7.
Jeff Farmer
HS 3, HSPhone
