Build 3.0.11.13 Issues with Weather Underground
    Tried the new Wunderground option. No joy. I put in the new API key and get the following problem when doing a conditions update:
    Jun-04 9:51:00 PM weatherXML Triggers to check: 0
    Jun-04 9:51:00 PM weatherXML Daily Scheule check for location 1 = 1
    Jun-04 9:50:49 PM weatherXML Check Condition Triggers
    Jun-04 9:50:49 PM weatherXML wXMLValueSetRef: 6/4/2019 9:50:49 PM
    Jun-04 9:50:49 PM weatherXML Run Script
    Jun-04 9:50:49 PM weatherXML Weather Underground Current Conditions Finished
    Jun-04 9:50:49 PM weatherXML Output XML
    Jun-04 9:50:49 PM weatherXML Error The search key was not found in any record.
    Jun-04 9:50:49 PM weatherXML Running delete query to remove old data.
    Jun-04 9:50:49 PM weatherXML Save info to database: INSERT INTO [current] (updatedTime, temperature, feelsLike, todaysHigh, todaysLow, lastYearsHigh, lastYearsLow, humidity, windSpeed, windDirection, windGust, windDegrees, visibility, dewpoint, barometer, barometerdir, moonPhase, weatherSpoken, locationID, rainToday, rainHour, curCondition) VALUES (#6/4/2019 9:50:49 PM#,'68','66','0','0','0','0','26','6','East','-999','70','10','32','30','0','21',Null,1, 0.00, 0.00, 'Mostly Cloudy')
    Jun-04 9:50:49 PM weatherXML Check to see if DB is being used. Save the data is set to Yes.
    Jun-04 9:50:49 PM weatherXML Set selected Speak Devices String
    Jun-04 9:50:49 PM weatherXML Error importWUConditions: Could not find file 'C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\DScondition1.json'.
    Jun-04 9:50:49 PM weatherXML importWUConditions
    Jun-04 9:50:49 PM weatherXML Status: True
    Jun-04 9:50:49 PM weatherXML Download and Import
    Jun-04 9:50:49 PM weatherXML Reset Hi Low
    Jun-04 9:50:49 PM weatherXML wXMLCurrent: Running current location 1
    Jun-04 9:50:49 PM weatherXML Schedule Location: 1
    Jun-04 9:50:49 PM weatherXML Schedule Type: Conditions
    I ran a wireshark packet sniffer to see what you are doing to get the wunderground data, and it appears that the call is not what is currently required:
    http://rtupdate.wunderground.com/wea...dmph=0.0&dail]
    The new "current conditions" call should be in the following format: As you can see, you will need to add the Station ID back to the locations screen for Wunderground connection.
    Not sure where your current code is getting my old Wunderground password from since there is nowhere to enter that anymore.
    I get the same Could not find file 'C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\DScondition3.json' error. My WU location is Location #3, so that is why it is DScondition3.json. The other locations using other services are working fine.
    Just an observation... when you wiresharked the packet, are you certain it was generated from WeatherXML? And do you have a weather station that uploads to WU? I ask this because the URL you sniffed appears to be the weather station (KCOLOUIS35) uploading to WeatherUnderground. That would explain why your password is being displayed in the URL. The WU upload protocol can be found at this link.
    https://feedback.weather.com/custome...col?b_id=17298
      My bad. I use the same computer to pass my PWS data to weatherunderground. So, that is obviously not the source of the problem. I will retest later today with the sniffer running. Thanks for catching that.
        The Weather Underground changes are not ready yet. I am working on them. When done, it will only provide Conditions and a 5 day forecast.
        Jeff Farmer
        HS 3, HSPhone
