I've been using this plugin to connect to my Davis Vantage Vue through Weather Underground for years. However, looks like it stopped working for me on March 25. I can't figure this out. Did something change with Weather Underground on March 25? When something stops working, the first reaction is to start playing with settings, so now I'm not 100% sure where I should be.
First question - which key do you use? When I log into my Weather Underground account and go to My Devices, I see a short 8-character key next to my device in the table. However, if I click on the API Key tab, it shows me a longer 32-character key. I've tried both, but neither seem to work. My account shows my membership is active until March 15, 2020.
Here are the log entries I am seeing:
Note the "Unauthorized" errors. Same error using both keys.
Please help.
Peter
Jun-08 9:46:46 AM | weatherXML | Check Condition Triggers |
Jun-08 9:46:46 AM | weatherXML | Weather Underground Current Conditions Finished |
Jun-08 9:46:46 AM | weatherXML | Output XML |
Jun-08 9:46:46 AM | weatherXML | Create Image |
Jun-08 9:46:46 AM | weatherXML | Check to see if DB is being used. Save the data is set to Yes. |
Jun-08 9:46:46 AM | weatherXML | Set selected Speak Devices String |
Jun-08 9:46:46 AM | weatherXML Error | Error File: WUCondition1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUCondition1.xml". |
Jun-08 9:46:46 AM | weatherXML | Import WU Conditions |
Jun-08 9:46:46 AM | weatherXML | Download Status: Failure |
Jun-08 9:46:46 AM | weatherXML Error | downloadFile: WU Condition from: http://api.wunderground.com/api/5b93...:IPRINCEE4.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. |
Jun-08 9:46:46 AM | weatherXML | Downloading the WU Condition file at http://api.wunderground.com/api/API/...:IPRINCEE4.xml. |
Jun-08 9:46:46 AM | weatherXML | Replacement URL: http://api.wunderground.com/api/API/...:IPRINCEE4.xml |
Jun-08 9:46:46 AM | weatherXML | Downloading file now. |
Jun-08 9:46:46 AM | weatherXML | Weather Underground Download per minute for WU Condition = 3 |
Jun-08 9:46:46 AM | weatherXML | Download WU Condition: 43 |
Jun-08 9:46:46 AM | weatherXML | Data from Station: IPRINCEE4 |
Jun-08 9:46:46 AM | weatherXML | Download and Import |
Jun-08 9:46:46 AM | weatherXML | Reset Hi Low |
Jun-08 9:46:46 AM | weatherXML | wXMLCurrent: Running current location 1 |
Jun-08 9:46:35 AM | weatherXML | Locations Allowed: 10, In Use: 3 |
Jun-08 9:46:35 AM | weatherXML | Found RefID: 453 |
Jun-08 9:46:35 AM | weatherXML | Check if this address exists: Location 1 Map Group |
Jun-08 9:46:35 AM | weatherXML Error | Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". |
Jun-08 9:46:35 AM | weatherXML | Download Status: Failure |
Jun-08 9:46:35 AM | weatherXML Error | downloadFile: WU Forecast from: http://api.wunderground.com/api/5b93....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. |
Jun-08 9:46:35 AM | weatherXML | Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. |
Jun-08 9:46:35 AM | weatherXML | Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml |
Jun-08 9:46:35 AM | weatherXML | Downloading file now. |
Jun-08 9:46:35 AM | weatherXML | Weather Underground Download per minute for WU Forecast = 2 |
Jun-08 9:46:35 AM | weatherXML | Download WU Forecast: 42 |
Jun-08 9:46:35 AM | weatherXML | Data from Station: IPRINCEE4 |
Jun-08 9:46:35 AM | weatherXML | The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. |
Jun-08 9:46:35 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:35 AM | weatherXML | Check if this address exists: Speak Items Root |
Jun-08 9:46:34 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:34 AM | weatherXML | Check if this address exists: Speak Items Root |
Jun-08 9:46:34 AM | weatherXML | page: weatherXML_loc, data: &id=menuTopLocations&menuTopLocations=Submit |
Jun-08 9:46:29 AM | weatherXML | Locations Allowed: 10, In Use: 3 |
Jun-08 9:46:29 AM | weatherXML | Found RefID: 453 |
Jun-08 9:46:29 AM | weatherXML | Check if this address exists: Location 1 Map Group |
Jun-08 9:46:29 AM | weatherXML Error | Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". |
Jun-08 9:46:29 AM | weatherXML | Download Status: Failure |
Jun-08 9:46:29 AM | weatherXML Error | downloadFile: WU Forecast from: http://api.wunderground.com/api/5b93....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. |
Jun-08 9:46:29 AM | weatherXML | Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. |
Jun-08 9:46:28 AM | weatherXML | Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml |
Jun-08 9:46:28 AM | weatherXML | Downloading file now. |
Jun-08 9:46:28 AM | weatherXML | Weather Underground Download per minute for WU Forecast = 1 |
Jun-08 9:46:28 AM | weatherXML | Download WU Forecast: 41 |
Jun-08 9:46:28 AM | weatherXML | Data from Station: IPRINCEE4 |
Jun-08 9:46:28 AM | weatherXML | The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. |
Jun-08 9:46:28 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:28 AM | weatherXML | Check if this address exists: Speak Items Root |
Jun-08 9:46:28 AM | weatherXML | page: weatherXML_loc, data: locwuAPI_1=5b933f97 |
Jun-08 9:46:23 AM | weatherXML | Locations Allowed: 10, In Use: 3 |
Jun-08 9:46:23 AM | weatherXML | Found RefID: 453 |
Jun-08 9:46:23 AM | weatherXML | Check if this address exists: Location 1 Map Group |
Jun-08 9:46:23 AM | weatherXML Error | Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". |
Jun-08 9:46:23 AM | weatherXML | Download Status: Failure |
Jun-08 9:46:23 AM | weatherXML Error | downloadFile: WU Forecast from: http://api.wunderground.com/api/1493....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. |
Jun-08 9:46:23 AM | weatherXML | Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. |
Jun-08 9:46:23 AM | weatherXML | Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml |
Jun-08 9:46:23 AM | weatherXML | Downloading file now. |
Jun-08 9:46:23 AM | weatherXML | Weather Underground Download per minute for WU Forecast = 0 |
Jun-08 9:46:23 AM | weatherXML | Download WU Forecast: 40 |
Jun-08 9:46:23 AM | weatherXML | Data from Station: IPRINCEE4 |
Jun-08 9:46:23 AM | weatherXML | The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. |
Jun-08 9:46:23 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:23 AM | weatherXML | Check if this address exists: Speak Items Root |
Jun-08 9:46:23 AM | weatherXML | page: weatherXML_loc, data: id=deviceSelector&deviceSelector=1 |
Jun-08 9:46:15 AM | weatherXML | Locations Allowed: 10, In Use: 3 |
Jun-08 9:46:15 AM | weatherXML | Found RefID: 455 |
Jun-08 9:46:15 AM | weatherXML | Check if this address exists: Location 3 Map Group |
Jun-08 9:46:15 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:14 AM | weatherXML | Check if this address exists: Speak Items Root |
Jun-08 9:46:14 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:14 AM | weatherXML | page: weatherXML_loc, data: id=deviceSelector&deviceSelector=3 |
Jun-08 9:46:11 AM | weatherXML | Locations Allowed: 10, In Use: 3 |
Jun-08 9:46:11 AM | weatherXML | Found RefID: 454 |
Jun-08 9:46:11 AM | weatherXML | Check if this address exists: Location 2 Map Group |
Jun-08 9:46:11 AM | weatherXML | Found RefID: 244 |
Jun-08 9:46:11 AM | weatherXML | Check if this address exists: Speak Items Root |
Please help.
Peter
