Weather Underground not working for me
I would suggest switching to DarkSky. They currently have the most data available for use.
I would also be interested in this when the new codes are written. Mine has been down since March also.
Non-urgent question - I use the Raspberry Pi version of Homeseer. Some funkiness to the UI, especially the weatherxml pages.While troubleshooting, I tried adding new Locations. I can add them okay, but UI will never save settings added to those pages. Looks like it does, but when you navigate away and then back, changes are lost. Now I'm trying to get rid of those test locations, but clicking on the Delete button does absolutely nothing.
This likely has nothing to do with your plug-in, but thought I'd ask anyway.
Peter
Ah... That explains it. I will turn on/off air conditioning/heat manually until the new API is ready. Thanks for your efforts.
Peter
The company that owns Weather Underground stopped the free access to their API. Since you have a weather station, you can get a new API key from WU. However, I have to rewrite all of the WU code for their new access. It will eventually provide Conditions and a 5 Day Forecast. I am working on the code to add the new WU API but it will be a few more weeks.
I've been using this plugin to connect to my Davis Vantage Vue through Weather Underground for years. However, looks like it stopped working for me on March 25. I can't figure this out. Did something change with Weather Underground on March 25? When something stops working, the first reaction is to start playing with settings, so now I'm not 100% sure where I should be.
First question - which key do you use? When I log into my Weather Underground account and go to My Devices, I see a short 8-character key next to my device in the table. However, if I click on the API Key tab, it shows me a longer 32-character key. I've tried both, but neither seem to work. My account shows my membership is active until March 15, 2020.
Here are the log entries I am seeing:
Jun-08 9:46:46 AM weatherXML Check Condition Triggers Jun-08 9:46:46 AM weatherXML Weather Underground Current Conditions Finished Jun-08 9:46:46 AM weatherXML Output XML Jun-08 9:46:46 AM weatherXML Create Image Jun-08 9:46:46 AM weatherXML Check to see if DB is being used. Save the data is set to Yes. Jun-08 9:46:46 AM weatherXML Set selected Speak Devices String Jun-08 9:46:46 AM weatherXML Error Error File: WUCondition1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUCondition1.xml". Jun-08 9:46:46 AM weatherXML Import WU Conditions Jun-08 9:46:46 AM weatherXML Download Status: Failure Jun-08 9:46:46 AM weatherXML Error downloadFile: WU Condition from: http://api.wunderground.com/api/5b93...:IPRINCEE4.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. Jun-08 9:46:46 AM weatherXML Downloading the WU Condition file at http://api.wunderground.com/api/API/...:IPRINCEE4.xml. Jun-08 9:46:46 AM weatherXML Replacement URL: http://api.wunderground.com/api/API/...:IPRINCEE4.xml Jun-08 9:46:46 AM weatherXML Downloading file now. Jun-08 9:46:46 AM weatherXML Weather Underground Download per minute for WU Condition = 3 Jun-08 9:46:46 AM weatherXML Download WU Condition: 43 Jun-08 9:46:46 AM weatherXML Data from Station: IPRINCEE4 Jun-08 9:46:46 AM weatherXML Download and Import Jun-08 9:46:46 AM weatherXML Reset Hi Low Jun-08 9:46:46 AM weatherXML wXMLCurrent: Running current location 1 Jun-08 9:46:35 AM weatherXML Locations Allowed: 10, In Use: 3 Jun-08 9:46:35 AM weatherXML Found RefID: 453 Jun-08 9:46:35 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:35 AM weatherXML Found RefID: 453 Jun-08 9:46:35 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:35 AM weatherXML Error Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". Jun-08 9:46:35 AM weatherXML Download Status: Failure Jun-08 9:46:35 AM weatherXML Error downloadFile: WU Forecast from: http://api.wunderground.com/api/5b93....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. Jun-08 9:46:35 AM weatherXML Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. Jun-08 9:46:35 AM weatherXML Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml Jun-08 9:46:35 AM weatherXML Downloading file now. Jun-08 9:46:35 AM weatherXML Weather Underground Download per minute for WU Forecast = 2 Jun-08 9:46:35 AM weatherXML Download WU Forecast: 42 Jun-08 9:46:35 AM weatherXML Data from Station: IPRINCEE4 Jun-08 9:46:35 AM weatherXML The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. Jun-08 9:46:35 AM weatherXML Found RefID: 244 Jun-08 9:46:35 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:34 AM weatherXML Found RefID: 244 Jun-08 9:46:34 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:34 AM weatherXML page: weatherXML_loc, data: &id=menuTopLocations&menuTopLocations=Submit Jun-08 9:46:29 AM weatherXML Locations Allowed: 10, In Use: 3 Jun-08 9:46:29 AM weatherXML Found RefID: 453 Jun-08 9:46:29 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:29 AM weatherXML Found RefID: 453 Jun-08 9:46:29 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:29 AM weatherXML Error Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". Jun-08 9:46:29 AM weatherXML Download Status: Failure Jun-08 9:46:29 AM weatherXML Error downloadFile: WU Forecast from: http://api.wunderground.com/api/5b93....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. Jun-08 9:46:29 AM weatherXML Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. Jun-08 9:46:28 AM weatherXML Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml Jun-08 9:46:28 AM weatherXML Downloading file now. Jun-08 9:46:28 AM weatherXML Weather Underground Download per minute for WU Forecast = 1 Jun-08 9:46:28 AM weatherXML Download WU Forecast: 41 Jun-08 9:46:28 AM weatherXML Data from Station: IPRINCEE4 Jun-08 9:46:28 AM weatherXML The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. Jun-08 9:46:28 AM weatherXML Found RefID: 244 Jun-08 9:46:28 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:28 AM weatherXML Found RefID: 244 Jun-08 9:46:28 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:28 AM weatherXML page: weatherXML_loc, data: locwuAPI_1=5b933f97 Jun-08 9:46:23 AM weatherXML Locations Allowed: 10, In Use: 3 Jun-08 9:46:23 AM weatherXML Found RefID: 453 Jun-08 9:46:23 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:23 AM weatherXML Found RefID: 453 Jun-08 9:46:23 AM weatherXML Check if this address exists: Location 1 Map Group Jun-08 9:46:23 AM weatherXML Error Error File: WUForecast1.xml Error Reason: Could not find file "/usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml". Jun-08 9:46:23 AM weatherXML Download Status: Failure Jun-08 9:46:23 AM weatherXML Error downloadFile: WU Forecast from: http://api.wunderground.com/api/1493....37,-63.03.xml. Error: System.Net.HttpWebResponse The remote server returned an error: (401) Unauthorized. Jun-08 9:46:23 AM weatherXML Downloading the WU Forecast file at http://api.wunderground.com/api/API/....37,-63.03.xml. Jun-08 9:46:23 AM weatherXML Replacement URL: http://api.wunderground.com/api/API/....37,-63.03.xml Jun-08 9:46:23 AM weatherXML Downloading file now. Jun-08 9:46:23 AM weatherXML Weather Underground Download per minute for WU Forecast = 0 Jun-08 9:46:23 AM weatherXML Download WU Forecast: 40 Jun-08 9:46:23 AM weatherXML Data from Station: IPRINCEE4 Jun-08 9:46:23 AM weatherXML The /usr/local/HomeSeer/Data/weatherXML/WUForecast1.xml file is missing. Unable to continue the data import. Jun-08 9:46:23 AM weatherXML Found RefID: 244 Jun-08 9:46:23 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:23 AM weatherXML Found RefID: 244 Jun-08 9:46:23 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:23 AM weatherXML page: weatherXML_loc, data: id=deviceSelector&deviceSelector=1 Jun-08 9:46:15 AM weatherXML Locations Allowed: 10, In Use: 3 Jun-08 9:46:15 AM weatherXML Found RefID: 455 Jun-08 9:46:15 AM weatherXML Check if this address exists: Location 3 Map Group Jun-08 9:46:15 AM weatherXML Found RefID: 455 Jun-08 9:46:15 AM weatherXML Check if this address exists: Location 3 Map Group Jun-08 9:46:15 AM weatherXML Found RefID: 244 Jun-08 9:46:14 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:14 AM weatherXML Found RefID: 244 Jun-08 9:46:14 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:14 AM weatherXML page: weatherXML_loc, data: id=deviceSelector&deviceSelector=3 Jun-08 9:46:11 AM weatherXML Locations Allowed: 10, In Use: 3 Jun-08 9:46:11 AM weatherXML Found RefID: 454 Jun-08 9:46:11 AM weatherXML Check if this address exists: Location 2 Map Group Jun-08 9:46:11 AM weatherXML Found RefID: 454 Jun-08 9:46:11 AM weatherXML Check if this address exists: Location 2 Map Group Jun-08 9:46:11 AM weatherXML Found RefID: 244 Jun-08 9:46:11 AM weatherXML Check if this address exists: Speak Items Root Jun-08 9:46:11 AM weatherXML Found RefID: 244 Note the "Unauthorized" errors. Same error using both keys.Jun-08 9:46:11 AM weatherXML Check if this address exists: Speak Items Root
Please help.
Peter
Tags: None
