I do something similar.
When the outside temperature goes above 20 Celcius, I have HS switch the Z-Wave thermostat to Cool Mode. When the outside goes below 10 Celcius --> Heat Mode. The thermostat mode is then used to control the behavior of several other events.
Previously, I'd used a date trigger to do the switch Spring and Fall, but since the weather is so variable around those shoulder seasons, I constantly found myself overriding that schedule. Those two settings provide a nice dead band so the system isn't constantly switching back and forth.
[Feature Request] Season tracking
Originally posted by Wadenut View PostNot sure what you'd use this for, but back in HS2 (I don't use it currently), I had an event triggered at midnight on March 21, June 21, September 21 and December 21 to set the season name in a virtual device. It also set the value of the device to 1=Spring, 2=Summer, 3=Fall, 4=Winter.
- 1 like
Any way to pull in the Season?Tags: None
