I recently added a Z-Wave thermostat and thought I would try out the Weather xml (3.0.1.19) plugin to help with events i would like to create. I setup the plug-in to gather data from NOAA. I seem to be able to gather current conditions but its the forecast data where I'm having problems. I did enable the forecast download schedule. I also set the log to weatherxml and see no errors when I manually run the forecast download. I'm sure I'm missing something obvious but I have no idea what it might be. Any help would be appreciated.
Log Output:
2019-11-15 04:46:28.8567633 PM weatherXML Start Up
2019-11-15 05:04:47.5003277 PM weatherXML Schedule Type: Forecast
2019-11-15 05:04:47.5003277 PM weatherXML Schedule Location: 1
2019-11-15 05:04:47.5003277 PM weatherXML wXMLValueSetRef: 11/15/2019 5:04:47 PM
2019-11-15 05:04:47.5158950 PM weatherXML Running Forecast
2019-11-15 05:04:47.5158950 PM weatherXML Forecast Source: noaa
2019-11-15 05:04:47.5158950 PM weatherXML Confirm Common Min Time
2019-11-15 05:04:47.5158950 PM weatherXML Set the value to use as the minimum time
2019-11-15 05:04:47.5158950 PM weatherXML Check override
2019-11-15 05:04:47.5158950 PM weatherXML Use for delay: 0
2019-11-15 05:04:47.5158950 PM weatherXML Check for last ran date
2019-11-15 05:04:47.5158950 PM weatherXML Check for last ran time
2019-11-15 05:04:47.5158950 PM weatherXML Last Ran: 11/15/2019 4:46:01 PM
2019-11-15 05:04:47.5158950 PM weatherXML Set the download minutes
2019-11-15 05:04:47.5158950 PM weatherXML lastDownloadMins: 18
2019-11-15 05:04:47.5158950 PM weatherXML File exists check: C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\NOForecast1.xml
2019-11-15 05:04:47.5158950 PM weatherXML Check download URL: True
2019-11-15 05:04:47.5158950 PM weatherXML Check URL http://forecast.weather.gov/MapClick...&FcstType=dwml
2019-11-15 05:04:47.5158950 PM weatherXML Check download API: True
2019-11-15 05:04:47.5158950 PM weatherXML Check download StationID: False
2019-11-15 05:04:47.5158950 PM weatherXML Check download Last Ran: False
2019-11-15 05:04:47.5158950 PM weatherXML Check download Daily Limit: False
2019-11-15 05:04:47.5158950 PM weatherXML Downloading the NOAA Weather Forecast file at http://forecast.weather.gov/MapClick...&FcstType=dwml.
2019-11-15 05:04:47.9377508 PM weatherXML Download Status: True
2019-11-15 05:04:47.9377508 PM weatherXML wXMLValueSetRef: 11/15/2019 4:49:47 PM
Configuration:
Devices:
Log Output:
Configuration:
Devices:
