Graphic for device Forecast Horizontal/Vertical - icons not updating
    I have uploaded custom PNG's which work perfectly for all forecasts except "Forecast Horizontal/Vertical "
    Click image for larger version  Name:	Capture9.JPG Views:	0 Size:	22.9 KB ID:	1346748
    Click image for larger version  Name:	Capture10.JPG Views:	0 Size:	65.1 KB ID:	1346749
    Any clue where the problem could be?
    Thx
    Have you checked the log to see if / which files are missing?
      Yes, doesn't seem to be anything wrong with the log (see below)
      Seems more like an internal process which is not logged in details;
      Weird that my icons get through for all forecasts but not these 2; maybe the png format is not compatible, I'll have to try other icons for testing or save under a different format maybe.
      2019-12-15 12:18:37.2434384 PM weatherXML page: weatherXML_hst, data: id=devGraphicHDays_1&devGraphicHDays_1=3
      2019-12-15 12:18:37.2444384 PM weatherXML wXMLValueSetRef: 3
      2019-12-15 12:18:37.2474386 PM weatherXML Check Graphic Forecast Horizontal Device. Use Days: 3
      2019-12-15 12:18:37.2494387 PM weatherXML Forecast Horizontal Device exists.
      2019-12-15 12:18:37.2884409 PM weatherXML Convert HTML To Image.
      2019-12-15 12:18:37.3194427 PM weatherXML Use image: /images/weatherXML/condition/horizontalForecast_1.png for HSTouch
      2019-12-15 12:18:37.3194427 PM weatherXML device refID: 1512
      2019-12-15 12:18:37.3204428 PM weatherXML Use Image File: C:\Program Files (x86)\HomeSeer HS3\html\images\weatherXML\condition\horizontalForecast_1.pn g
      2019-12-15 12:18:37.3214428 PM weatherXML Device current value: -999
      2019-12-15 12:18:37.3214428 PM weatherXML File Name: /images/weatherXML/condition/horizontalForecast_1.png, set to value: 100
      2019-12-15 12:18:37.3254430 PM weatherXML Device Status Values Set
      2019-12-15 12:18:37.3254430 PM weatherXML Finished function.
      2019-12-15 12:18:37.3254430 PM weatherXML Set Status Graphics.
      2019-12-15 12:18:39.0065392 PM weatherXML page: weatherXML_hst, data: id=devGraphicVDays_1&devGraphicVDays_1=3
      2019-12-15 12:18:39.0075393 PM weatherXML wXMLValueSetRef: 3
      2019-12-15 12:18:39.0095394 PM weatherXML Check Graphic Forecast Vertical Device. Use Days: 3
      2019-12-15 12:18:39.0105394 PM weatherXML Forecast Vertical Device exists.
      2019-12-15 12:18:39.0485416 PM weatherXML Use image: /images/weatherXML/condition/verticalForecast_1.png for HSTouch
      2019-12-15 12:18:39.0485416 PM weatherXML device refID: 1513
      2019-12-15 12:18:39.0505417 PM weatherXML Use Image File: C:\Program Files (x86)\HomeSeer HS3\html\images\weatherXML\condition\verticalForecast_1.png
      2019-12-15 12:18:39.0505417 PM weatherXML Device current value: -999
      2019-12-15 12:18:39.0505417 PM weatherXML File Name: /images/weatherXML/condition/verticalForecast_1.png, set to value: 100
      2019-12-15 12:18:39.0535419 PM weatherXML Device Status Values Set
      2019-12-15 12:18:39.0535419 PM weatherXML Finished function.
        I use png & jpg format and don't seem to have problems. Have you looked in the WeatherXML log file to see if there is anything?
          yes see above.
          I've tried changing to jpg. all forecasts icons gone. Must need png.
          saved again under png with different software. all forecasts icons back on, except vertical/horizontal.
            Sorry - mistook for homeseer log.
            If you go look at the file in the directory, does it display correctly? If not do you have the days you wish to download sent in the legacy section of WXML?
              File is the same in the \HomeSeer HS3\html\images\weatherXML\condition directory
              both vertical/horizontal are processed without icons.
              Any way to reset this feature? used to work before I changed the icons.
              everything else works perfectly:
              Here's my config,
              Also added this to legacy but It used to work even without it:
              Also looked at this thread :
              https://forums.homeseer.com/forum/weather-plug-ins/weather-discussion/weatherxml-cfguy/1299128-tiny-graphics-for-forecast-horizontal-and-forecast-vertical
              No success so far....
                from CFGuy's post
                "instead of using HTML in the device string which kept them from being used in HSTouch, I used the code to create an actual image"
                Did any of the filenames change - even slightly? This could break his code that concatenates the images. The post also says that he went back to html.
                  Did further testing, manually deinstalled everything and all of a sudden some old icons came back in vertical/horizontal, so they must be stored somewhere and I need to reset or delete everything. Any clue where the code resides?
                    I think it is in the plugin.
                      I completely deinstalled the plugin and resinstalled from the plugin manager, so the icons must be stored elsewhere... just need to force a refresh which doesn't seem to happen automatically.... Seems like the first time I put valid icons they were uploaded somewhere and won't re-update if changed...
                      Edit: The Legacy vertical/horizontal works but still no luck with the standard vertical/horizontal.... still displays icons I deleted a few days back, they don't even exist on the server anymore so must be stored/embedded in some file
                        Have you set the schedules for update? Might be worthwhile to send a PM to CFGUY as he is incredibly responsive.
                        Click image for larger version  Name:	Screenshot from 2019-12-15 14-10-51.png Views:	0 Size:	140.1 KB ID:	1346899
                          yes and I guess a manual "run now" should do it...
                          CFGUY has posted a sticky mentioning he wouldn't be around for a while since his mother has health issues.
                          Hopefully he'll eventually see this post and respond.
                          Thx,
                            Just adding this screenshot for reference;
                            you can notice that the update is done at the same time and regular forecasts use the correct icons (from "condition" folder)
                            but for some reason, horizontal/vertical forecast still uses some test PNG I used originally which seem to be stored somewhere else and not updated.
                              There are name devices that weatherXML is using. My devices are below.
Name:	Screenshot from 2019-12-19 16-07-20.png
                              I am wondering if you have to overwrite the files with the same name as uses / expects. The Icon names do not have any status graphics when you look inside which means he is probably setting them in the plugin.
