Darksky stopped working
    #16
    False alarm...still not working
      #17
      +1 I too have started noticing the same errors in my log. Anyone know if Jeff has been monitoring this thread?
      Plugin's:
        #18
        Mine at least pulled some of the data and updated some data...while we may end up changing something this is clearly a server side issue. It's come and gone a couple times now with me making no changes on my end.
          #19
          I don't understand this. I'm have not seen any issues or exceptions at all. I wonder if this is regional...
            #20
            I ran into the same error with my app. Farmer just needs to add this and he should be able to get it restored pretty quick. I had to go through the same thing when MyQ stopped working last year. Same fix works for Dark Sky API connections.
                    System.Net.ServicePointManager.Expect100Continue = True
                    System.Net.ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12
            Update: Just received an email from Dark Sky explaining what we had already uncovered. It would have been nice if they would have emailed their API subscribers prior to deploying the change.
            Hi Matt,
            Apologies for the trouble here. At 5 PM Eastern Standard Time yesterday (March 4, 2020), we applied a few security updates in line with the recommendations of a recent security audit, then reverted it over the weekend and reapplied it yesterday at 5 PM EST. This has resulted in us ultimately dropping the following SSL protocols and ciphers:
            • TLS 1.0
            • TLS 1.1
            • TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
            • TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
            • TLS_RSA_WITH_AES_128_GCM_SHA256
            • TLS_RSA_WITH_AES_128_CBC_SHA256
            • TLS_RSA_WITH_AES_256_GCM_SHA384
            • TLS_RSA_WITH_AES_256_CBC_SHA256
              #21
              [mention]CFGuy [/mention] Jeff, you happen to have any time to look into this issue?
              Plugin's:
                #22
                Great! I added
                    System.Net.ServicePointManager.SecurityProtocol = System.Net.SecurityProtocolType.Tls12
                to my script and it's updating again.
                Thanks!
                  #23
                  I have been up as well since yesterday (no idea if it dropped out again at some time between), but after running a network team for a couple decades the guys doing the patches have my sympathy...at least to some point . My setup is purely through the plugin and I've changed nothing. For it to happen more than once over the last couple weeks probably means they have some openings on their team. I just appreciate it's still a free service!
                    #24
                    Originally posted by zwolfpack View Post
                    Great! I added
                    Thanks!
                    I tried adding this to a script but it errors. I using an IMPORTS statement before running the script. Is this not the correct way to add this?
                    Don
                      #25
                      Great! I added
                      Thanks!
                      I confirm this addition has gotten my script working again. Special thanks to phuz for figuring this out and confirming w/ the folks at Dark Sky.
                      Agreed that it would have been nice for them to give their API users a heads up. But I won't complain since it is free
                      I wonder if they notified their paying customers....
                        #26
                        Is the statement inside the sub or function?
                        I had problems as well initially because I put the statement right after my IMPORTS statement, i.e. outside of the Main sub. After moving to inside the Main sub, it started working.
                          #27
                          It is outside the Sub.
                          Could you show me how you are calling it inside the Main?
                          Thanks for the help
                          Don
                            #28
                            Full script
                            Note that main routine is named 'Current'. Either rename this to 'Main' or set 'Current' in the 'Sub or Function' field of the event action.
                            Event action 'Parameters' field is set to 'Darksky'.
                            Imports Newtonsoft.Json
                            Dim errmsg As String
                            Sub Current(p As String)
                                Dim Debug As Boolean = hs.GetINISetting("Settings", "Debug", "False", "DarkSky.ini")
                                Dim logName As String
                                Dim pa As String() = Split(p, "|")
                                Dim Location As String = pa(0)
                                logName = Location
                                Dim apikey As String = hs.GetINISetting("Settings", "weatherapikey", "", "DarkSky.ini")
                                If Debug Then hs.WriteLog(logName, "API key: " & apikey)
                                Dim dLatitude As Double = hs.GetINISetting("Settings", "gLatitude", "0")
                                Dim dLongitude As Double = - hs.GetINISetting("Settings", "gLongitude", "0")
                                If Debug Then hs.WriteLog(logName, "Latitude,Longitude: " & CStr(dLatitude) & "," & CStr(dLongitude))
                                Dim host As String = "https://api.darksky.net"
                                Dim page As String = "/forecast/" & apikey & "/" & dLatitude & "," & dLongitude & "?exclude=alerts,flags,daily,hourly,minutely"
                                Dim strip_tags As Boolean = False
                                Dim port As Integer = 443
                                Try
                            '        Dim webClient As New System.Net.WebClient
                            '        Dim resp As String = webClient.DownloadString(host & page)
                                    Dim resp As String = hs.GetURL(host, page, strip_tags, port)
                                    If Left(resp, 6) = "ERROR:" Then
                                        ' only report initial instance
                                        If errmsg <> resp Then hs.WriteLogEx(logName, resp, "#ff0000")
                                        errmsg = resp
                                        return
                                    End If
                                    If errmsg <> "" Then
                                        ' error cleared
                                        errmsg = ""
                                        hs.WriteLogEx(logName, "error condition cleared", "#008000")
                                    End If
                                    Dim obj As Object = JsonConvert.DeserializeObject(resp)
                                    Dim currently As Object = obj.Item("currently")
                                    Dim cloudCover As Double = currently.Item("cloudCover") * 100
                                    If Debug Then hs.WriteLog(logName, "cloud cover: " & cloudCover)
                                    hs.SetDeviceValueByName(Location & " Cloud Cover", cloudCover)
                                    Dim humidity As Double = currently.Item("humidity") * 100
                                    If Debug Then hs.WriteLog(logName, "humidity: " & humidity)
                                    hs.SetDeviceValueByName(Location & " Humidity", humidity)
                                    Dim pressure As Double = currently.Item("pressure")
                                    If Debug Then hs.WriteLog(logName, "pressure: " & pressure)
                                    hs.SetDeviceValueByName(Location & " Pressure", pressure)
                                    Dim temperature As Double = currently.Item("temperature")
                                    If Debug Then hs.WriteLog(logName, "temperature: " & temperature)
                                    hs.SetDeviceValueByName(Location & " Temperature", temperature)
                                    Dim uvIndex As Double = currently.Item("uvIndex")
                                    If Debug Then hs.WriteLog(logName, "uvIndex: " & uvIndex)
                                    hs.SetDeviceValueByName(Location & " UV Index", uvIndex)
                                    Dim visibility As Double = currently.Item("visibility")
                                    If Debug Then hs.WriteLog(logName, "visibility: " & visibility)
                                    hs.SetDeviceValueByName(Location & " Visibility", visibility)
                                    Dim windBearing As Double = currently.Item("windBearing")
                                    If Debug Then hs.WriteLog(logName, "wind direction: " & windBearing)
                                    hs.SetDeviceValueByName(Location & " Wind Direction", windBearing)
                                    Dim windSpeed As Double = currently.Item("windSpeed")
                                    If Debug Then hs.WriteLog(logName, "wind speed: " & windSpeed)
                                    hs.SetDeviceValueByName(Location & " Wind Speed", windSpeed)
                                Catch ex As Exception
                                    'Error trapping
                                    Dim exmsg As String = ex.ToString
                                    If errmsg <> exmsg Then hs.WriteLogEx(logName, exmsg, "#ff0000")
                                    errmsg = exmsg
                                End Try
                            End Sub
                              #29
                              Thanks. Perfect!
                              Don
                                #30
                                Full script
                                    logName = Location
                                    Try
                                            If errmsg  resp Then hs.WriteLogEx(logName, resp, "#ff0000")
                                            errmsg = resp
                                            return
                                        End If
                                        If errmsg  "" Then
                                            ' error cleared
                                            errmsg = ""
                                        End If
                                        'Error trapping
                                        If errmsg  exmsg Then hs.WriteLogEx(logName, exmsg, "#ff0000")
                                        errmsg = exmsg
                                    End Try
                                End Sub
                                Really sorry, I’m not understanding this fix. What script are you editing? Is this a script that is installed with the plugin? Where are you finding this file?
                                Plugin's:
