I think this a stand alone script meant to run as a event. I don't think It has anything to do with the plugin.
Darksky stopped working
Originally posted by MStan View PostI think this a stand alone script meant to run as a event. I don't think It has nothing to do with the plugin.
Sent from my iPhone using TapatalkHS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Originally posted by The Profit View PostWill it update the existing weatherXML devices or create its own?
The script doesn't create the devices, that was done manually.
I'm afraid that the solution that phuz found will need to be incorporated into the plugin by the author to get that working.
Originally posted by zwolfpack View Post
Sorry for the confusion. The script has nothing to do with the plugin. Its an alternate method to display Darksky data in devices.
Originally posted by phuz View Post
Exactly. This "fix" needs to be incorporated in the script. I was merely pointing out what he has to do to resolve it. I started writing my own plugin and scripts so that I wouldn't be at the mercy of others when things inevitably break. I'm too impatient to wait for plugin updates.
Plugin's:
Hi all. I found a workaround to get this working with minimal effort. In summary, the WeatherXML plugin appears to be a .NET application. You should be able to force the app to use TLS v1.2, which is now required by DarkSky, by updating the .NET config file.
At the root of the HS3 directory, you should see two files:
HSPI_WEATHERXML.exe - This is the application itself
HSPI_WEATHERXML.exe.config - This is the .NET config file
Add the following line (bold and in red) to the config file (assuming yours looks similar), then stop/restart the plugin. This should make it start working again by forcing the HSPI_WEATHERXML.exe application to use TLS v1.2.
Code:<?xml version="1.0"?> <configuration> <startup> <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/> </startup> <runtime> <AppContextSwitchOverrides value="Switch.System.Net.DontEnableSystemDefaultTlsVersions=false"/> <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"> <probing privatePath="bin/weatherXML;bin"/> </assemblyBinding> </runtime> </configuration>
~Joe
UPDATE: The above fix is for Windows 10 only
Windows 7
Thanks to The Profit (in post #44 below)
https://manage.accuwebhosting.com/kn...Windows-7.html
Windows 2k8 R2
Thanks to brantz (in post #47 below)
https://support.quovadisglobal.com/k...r-2008-r2.aspx
- 4 likes
Originally posted by prsmith777 View PostI emailed Jeff this morning to make him aware of this issue. Let's hope he has time to respond.
I've been looking around at the other options for weather and everything else requires a device on your roof. It seems I will need to start looking into picking one up. Anyone have any experience with the other plugins that they could suggest looking into? WeatherXML has just been a great plugin, it's going to be hard to beat!HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
Originally posted by jplandry View PostHi all. I found a workaround to get this working with minimal effort. In summary, the WeatherXML plugin appears to be a .NET application. You should be able to force the app to use TLS v1.2, which is now required by DarkSky, by updating the .NET config file.
<configuration>
<startup>
</startup>
<runtime>
<AppContextSwitchOverrides value="Switch.System.Net.DontEnableSystemDefaultTlsVersions= false"/>
</assemblyBinding>
</runtime>
</configuration>
Hope this helps!
~Joe
I tried to add the above bold statement to the config file and it is still giving me errors in the log and not updating, did I do something incorrect?
Plugin's:
- 2 likes
Hi Joe,
I discovered this fix by the following article ...
https://kevinchalet.com/2019/04/11/f...ecompiling-it/
I just added that line, restarted the plugin, then forced an update and it worked without any issues. I have HomeSeer set for 15 minute updates, and it has been running for a couple of hours now without any errors after that fix was added (while I was getting errors every 15 minutes before).
Also, I just realized that my original post had a space after "= false" while the article shows "=false". I don't think that space will make a difference, but you may want to try removing it just in case.
Hello. Sorry to hear that it did not work for you. Did you happen to stop/start the plugin after you made the change to ensure the config file took effect?
Also, I just realized that my original post had a space after "= false" while the article shows "=false". I don't think that space will make a different, but you may want to try removing it just in case.
If you're still using Windows 7, you'll also have to tweak the registry to enable TLS 1.2 support, as indicated on https://docs.microsoft.com/en-us/win...istry-settings.
The TLS 1.2 Key (folder) wasn't there originally, only the SSL 2.0, so I created the TLS 1.2 Key and subkey Server and then created the Enabled entry and changed the value to 1 as indicated in my link above. Is this the correct way to add? I can't imagine creating these keys is all that is needed to enable TLS 1.2?
Plugin's:
So I found another website that describes how to enable TLS 1.2 on in Win7 OS, made sure everything is correct, removed the space in the statement and rebooted the computer.
Everything seems to be working again! Thank you Joe for your help!!
Here is the link if anyone else is running HS on a Win7 machine: https://manage.accuwebhosting.com/kn...Windows-7.htmlHS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
- 1 like
<configuration>
<startup>
</startup>
<runtime>
</assemblyBinding>
</runtime>
</configuration>
Hope this helps!
~Joe
- 1 like
