Error under HS4
    Error under HS4
    Hi guys, after upgraded to HS4 I am seeing error below in log while starting HS4.
    Does anyone know what that error is about? CFGuy ?
    Thanks Charles
    Afraid I won't be able to help with HS 4 errors. I am still running HS3 and don't plan on upgrading to HS4.
    Jeff Farmer
    HS 3, HSPhone
      I am running version 3.0.1.19 of weather XML without issue.
      I followed the ALTERNATE upgrade method as posted on Homeseer website for HS4.
      I did not upgrade HS3, I installed HS4 Fresh and moved over a few folders per the instructions.
      Then I added WeatherXML plugin from HS4 Plugin page. Then i copied all things from my HS3 machine that was weatherXML related overwriting them in HS4.
      I made a zip folder of HS4 everytime before adding a new plugin so I could easily revert if need be.
      -Nacman
