NOAA error and Pushover alert trigger action not working
    I know Jeff's out right now, but wanted to throw this out there in case someone else has run into this and found a solution.
    I'm running version 3.0.1.19 of the plugin and during a bad line of severe weather this morning, I noticed the following error in the logs. This seems to happen whenever there is an active warning for my area. The alert trigger still works, but wondered if anyone else had this error in their logs and what could be causing it.
    Mar-22 07:02:34 weatherXML Error importNOAAFullText: StartIndex cannot be less than zero. Parameter name: startIndex
    Also, I have pushover configured in the plugin and it works for other events in homeseer, but I've noticed that it no longer works as an alert trigger action in weatherXML, even though everything is configured and was working in the past. My speaker clients receive the spoken text from the alert trigger, but I didn't receive any pushovers from the plugin. I didn't see any errors in the log file at the time of the alert.
