Custom Data For Australian Users
This is a sticky topic.
    #46
    No problem at all!
    Cheers
      #47
      I can't understand how to get this working? When I click on "Australia Weather Info" link "Get URL" -
      I get:
      This utility will generate a URL that is used to build a XML data feed from the BOM.
      If you find a location or observation point is not listed below please contact us with the details.
      Note: Your browser must support javascript to use this utility.
        #48
        I get:
        It appears not to be functional currently, but it basically builds the URL based on STATE, LOCATION, and STATION
        Example: VIC
        http://www.bom.gov.au/vic/forecasts/melbourne.shtml for LOCATION = MELBOURNE
        http://www.bom.gov.au/vic/observations/melbourne.shtml for STATION = (1) MELBOURNE AIRPORT or (2) LAVERTON
        OUTPUT:
        (1) https://right-click.com.au/misc/weat..._type=detailed
        (2) https://right-click.com.au/misc/weat..._type=detailed
          #49
          Example: VIC
          OUTPUT:
          Yeah, I've seen this example for MELBOURNE AIRPORT, but how do I select another location?
            #50
            I have only ever been able to get data from either Melbourne Airport or Laverton return data. So I cannot help further. PM @Megaman
              #51
              Ok, thank you brientim . I tried also DarkSky, but it gives 5 degrees error, a bit too much
                #52
                Hey guys, have an issue with some fields not updating using custom URL
                http://right-click.com.au/misc/weath..._type=detailed
                schedules are set for the forecast to run every 4 hours.
                See the screenshot. See highlight yellow. Not sure why these fields only update at 6:19 am in the morning. Others are ok. I'm using some of these devices is HSTouch. specifically the earlwood low and earlwood high and day name ranges. Some of those are updated in the screenshot as I unchecked/rechecked them. They were showing the same timestamp 6:19 am as the others.
ID:	1430401Click image for larger version
