Release Info for weatherXML for HS3
This topic is closed.
  • #16
    3.0.0.16
    * The Alerts now correctly import the Event name. This is a short version of the Title. Variable #alertEvent# is available for replacement variables.
    * Add the prepend and append to the Temp, Temp Feels, Record High, Record Low values as new fields in the output xml file.
    * Add to Event Triggers: Only trigger if the Condition has changed from last update
    * Fixed bug that was not adding the Prepend and Append values to the HSTouch Barometer direction.
    * If you are using PHLocation, the Location device for the selected weatherXML Location now appends the current city to your entered name for the location.
    * Modified the Moon Phase logic used to determine the next New Moon and Full Moon.
    * Map Dropdown setting is now by location instead of one setting that controlled All Locations.
    * HSTouch screens for weatherXML data is now placed in the HomeSeer HS3\Docs\weatherXML directory. Weatherxml.xml uses devices. You will have to edit the screens to use your devices. weatherXML_RSS.xml uses the output xml file for the current conditions screen. You will have to edit the Forecast screen to use your devices.
    Jeff Farmer
    HS 3, HSPhone
    • #17
      3.0.0.17
      * Added logic to handle the Moon Phase offset when it causes the value to go above 29.
      * Added an option to choose between 2 sets of moon icons. Go to the locations page and select between Set 1 and Set 2. You can view the icons in the HomeSeer HS3/html/images/weatherXML/moon and moon2 directories.
      * Fixed error when adding a new alert trigger and one or more locations have been deleted.
      * New version of HSTouch weatherXML_RSS.xml that requires no editing on any of the screens. The files are in the HomeSeer HS3/Docs/weatherXML directory in a zip file called hstouch.zip
      Jeff Farmer
      HS 3, HSPhone
      • #18
        3.0.0.18
        * Added test data to test the Alert Triggers
        * Add email addresses to, email address from and email subject to alert triggers to send an email for the alerts.
        * Fixed bug where the HSTouch Condition Icon Device checkbox would not stay checked.
        * Add an image rotator for HSTouch forecast images. Add the device on the HSTouch device setup page at the top of the forecast section.
        * Added new Event Action. Change Forecast image to a particular days image.
        * Fixed bug where Regions that use a comma for the decimal seperator were not displaying correctly. Ex. 3.4 became 34.
        * Fixed bug that was causing some of the Custom Text phrases to ignore the value entered on the custom page.
        Jeff Farmer
        HS 3, HSPhone
        • #19
          3.0.0.19
          * Fixed the bug with numbers that use a comma for the decimal separator.
          Jeff Farmer
          HS 3, HSPhone
          • #20
            3.0.0.20
            * Fixed bug that caused the barometer value to be spoken for both barometer and barometer direction.
            * Fixed deviceString not working with the Speak Items.
            Jeff Farmer
            HS 3, HSPhone
            • #21
              3.0.0.21
              * Fixed the plugin config file to work with Linux.
              * Fixed a bug with the SQLite reference that caused the creation of the database to fail.
              * Added a dropdown to select a default city for VR in the event actions. If a location is spoken, the spoken location will be used. If no location is spoken the default selected in the dropdown will be used.
              Jeff Farmer
              HS 3, HSPhone
              • #22
                3.0.0.22
                * On the Units page, when the unit is changed, the values are now updated immediately rather than waiting on the next schedule for Current, Forecast, Daily and Hourly. No downloads run. The data is updated using the already existing xml files.
                * Changed the code that downloads the xml files to work with NOAAs server security changes. This fixes the error with the Forbidden message.
                * Condition text is now correctly being added to the Custom page to allow editing for languages other than english.
                Jeff Farmer
                HS 3, HSPhone
                • #23
                  3.0.0.23
                  * Trigger Alerts now has a separate Speak and Email text. Moved the text areas to the main edit screen.
                  * Add a More Info link to alert variables. This is a link to more information about the alert. Can be used in emails.
                  * Add a Random Phrase to the alert variables.
                  * Repeat numbers for alerts now correctly uses the Severity repeat times.
                  * Added a separate NOAA import for the overnight issue with the incorrect dates in the NOAA xml file.
                  * VR Control can now get up to the next 5 days of temperatures or forecasts. Need to select the event name on the settings page. Click Submit without changing the name. This will set the VR string to the new phrase. You can then say "Tell me the next three days forecast".
                  * World Weather Online is now providing forecast precipitation as a percent. You will want to change the units page to use % or percent for the precipitation unit.
                  * Pushover Plugin Integration: Alert Triggers now has the ability to integrate with the PushOver Plugin to send PushOver texts. Message, Message Title and URL Title can use the alert replacement variables. Edit an Alert Trigger to select PushOver device, App, Sound, Priority, Message Title, Message, Pushover URL title and for the Pushover URL it will use the link to More Info on the alert.
                  Jeff Farmer
                  HS 3, HSPhone
                  • #24
                    3.0.0.24
                    * Selecting SQL Server as the database now displays a button to create the table. Network Path and Database Name must be corrected entered before the table can be created.
                    * The import for World Weather Online forecast has been re written to now import night values. Night Condition, Night Condition Image, Night Forecast and Night Precipitation percentage will now work with WWO.
                    Jeff Farmer
                    HS 3, HSPhone
                    • #25
                      3.0.0.25
                      * Removed text on the Units page that said to enter millimeters instead of percent for World Weather Online forecast data for precipitation. As of 3.0.0.23, World Weather Online provides percent for forecast precipitation.
                      Jeff Farmer
                      HS 3, HSPhone
                      • #26
                        3.0.0.26
                        * Removed the VR trigger by dropdown. Setting this in the event is not supported in HS3. There are more options in HS3 then there were in HS2. You can select it manually when you create the event.
                        * Added Data Provider, Todays High, Todays High Time, Todays Low, Todays Low Time and UV to HSTouch Current Condition Devices.
                        * Added Data Provider information to users forecast, hourly, data and alert pages. This meets the requirement for terms of use.
                        * Alert Trigger Keywords now checks the Alert Event text for a match.
                        * Added separate trigger tracking for Email for each alert.
                        * Added separate trigger tracking for PushOver text for each alert.
                        Jeff Farmer
                        HS 3, HSPhone
                        • #27
                          3.0.0.27
                          * Added a Forecast Trigger and Conditions for use in HS events. Select from Temperature Day High, Temperature Day Low, Wind Speed, Day Condition, Night Condition, Day Precipitation % and Night Precipitation %. Select from today to 9 days ahead. The number of days ahead is dependent on which data provider you use.
                          * Fixed bug that was not setting the HSTouch night precipitation devices.
                          * Fixed The Current Condition Trigger and Condition for Condition Contains and Not Contains words. The bug would not find Cloudy in Partly Cloudy. It would only find an exact match. Ex. Partly Cloudy in Partly Cloudy.
                          Jeff Farmer
                          HS 3, HSPhone
                          • #28
                            3.0.0.28
                            * Added an extra textbox to the units page so you can have one for display and one for speaking. Ex for speed. Display: mph Speak: miles per hour. Both display and speak will default to your current entry until you edit them.
                            * Alerts can now email multiple addresses by comma separating the email addresses on the Alert Triggers edit page.
                            * Rewrote the way I store speak items. This will allow for adding more options in the future. PLEASE MAKE A BACKUP OF YOUR weatherSpeak.ini file before upgrading. I tested and tested this to make sure the previous setups were converted corredtly but please backup weatherSpeak.ini. If you don't I won't be able to help you get your Speak Items settings fixed if there is an error. weatherSpeak.ini is in the HomeSeer HS3/config/weatherXML directory.
                            I will be posting this new version later tonight.
                            Jeff Farmer
                            HS 3, HSPhone
                            • #29
                              3.0.0.29
                              * The weather alerts last alert device no longer gets set to hidden. This allows using the device in HSTouch. Set the device status graphics like in the image below. Add the device image to your HSTouch pages. When there are no alerts the transparent image is not seen. When there are alerts the image you choose for alerts will be seen.
                              * Changes to the Feels like forumla. If temps are above 80 then temperature, humidity and wind speed is required for the formula. Below 80 only the temperature and wind speed is required.
                              * Added the ability to use the Kinect plugin for VR.
                              Jeff Farmer
                              HS 3, HSPhone
                              • #30
                                3.0.0.30
                                * Fixed an issue where line returns in text areas was not being saved if HS was restarted. This resulted in losing any text after the line break.
                                * Current conditions now saves the wind direction and the wind string as the actual text not the abbreviation. Ex. Southwest instead of SW Previously, if the data was provided as SW that is what was imported.
                                Jeff Farmer
                                HS 3, HSPhone
