Release Info for weatherXML for HS3
This topic is closed.
    #46
    3.0.0.47
    Speak Devices
    <TABLE style="WIDTH: 335pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=446 border=0> <COLGROUP> <COL style="WIDTH: 335pt; mso-width-source: userset; mso-width-alt: 16310" width=446> <TBODY> <TR style="HEIGHT: 12.75pt" height=17> <TD style="BORDER-TOP: #f0f0f0; HEIGHT: 12.75pt; BORDER-RIGHT: #f0f0f0; WIDTH: 335pt; BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent" height=17 width=446> * Added an option to select a wav or mp3 file to play before the speaking.
    Devices
    * The Misc Group Parent Device has some options on the weatherXML tab. Select to setup a Spoken Log Device. You can keep a log of the last 5, 10 or 25 things that weatherXML speaks.
    * Fixed the pathway for the device image.
    </TD></TR></TBODY></TABLE>
    Jeff Farmer
    HS 3, HSPhone
      #47
      3.0.0.48
      Documentation
      * Added a new pdf to document the Schedules page.
      Jeff Farmer
      HS 3, HSPhone
        #48
        3.0.0.49
        Devices
        * Fixed Humidity Prepend for HSTouch Devices
        Plugin
        * Removed the Speak on Startup option
        * Fixed proper Version Number
        Documentation
        * Added Documentation for Misc Devices and new Last Spoke Log Device
        Jeff Farmer
        HS 3, HSPhone
          #49
          3.0.0.50
          XML Output
          * Fixed error that was looking at the wrong ini setting for the port number that HS3 is using.
          Jeff Farmer
          HS 3, HSPhone
            #50
            3.0.0.51
            weatherXML Event Triggers
            * Added Equals to weatherXML Condition events
            Replacement Speak variables
            * Added test mode to the alert replacement variables function (replaceVariablesAlert)
            * Add Sunrise and Sunset to speak device variables
            Devices
            * The HSTouch Moon Phase was not setting the device string.
            Database
            * Added database table to save the daily access totals by provider.
            Jeff Farmer
            HS 3, HSPhone
              #51
              3.0.52
              Devices
              * Fixed bug that was not setting the Solar Radiation device
              Debug
              * Fixed log output to not put the API in the logged URL
              Speak Devices
              * Added code for the forecast day and night condition text to use the Custom condition text.
              * Fixed error with loading the custom condition values
              * Fixed bug where the selected speak device's text was not getting set during the locations conditions schedule run
              * Added code to select a speak device for the forecast info as well as the condition info.
              * Added condition speak device text to the output xml file. Key: current/conditionString Existing forecast/speakString xml key is still in the xml file.
              * Added forecast speak device text and condition speak device text to the output xml file. forecast/forecastString
              Plugin Integration
              * PHLocation is now available for more than one location
              Location Setup
              * Added Section headers on the Locations page to make each stand out more.
              * Moved PHLocation Setup to locations page to allow any location to be a follow me.
              Jeff Farmer
              HS 3, HSPhone
                #52
                3.0.0.53
                Plugin Integration
                * Changed PHLocation device dropdown to match on plugins interface instead of the editable Location 1.
                Alerts
                * Now removes the * from the alert text.
                Jeff Farmer
                HS 3, HSPhone
                  #53
                  3.0.0.54
                  Locations
                  * Fixed an error where the selected Forecast Device was not being saved correctly.
                  * Fixed a bug where the xml output file variables were not getting set on plugin startup.
                  HS Events
                  * Add HS event action to turn off individual downloads instead of just all downloads.
                  * Add HS event action to turn on individual downloads instead of just all downloads.
                  Speak Devices
                  * Added a variable to allow adding a delay in the Speak Devices. From 1 to 19 Seconds.
                  Jeff Farmer
                  HS 3, HSPhone
                    #54
                    3.0.0.55
                    Speak Devices
                    * Added a play after media file to speak devices. You can now play a wav or mp3 both before and after the speaking.
                    Alert Triggers
                    Plugin Integration
                    * Modified the code to look at the PHLocation device value as well as the string when finding the Latitude, Longitude and Location City.
                    Jeff Farmer
                    HS 3, HSPhone
                      #55
                      3.0.0.56
                      * Location Setup
                      A new option added to allow you to have weatherXML use the Station ID only for Current Conditions. All the other data (Forecast, Daily, and Hourly) will use the Latitude and Longitude. To set this option, select a Station in the Station ID dropdown. The checkbox will be displayed below the Station ID dropdown.
                      Jeff Farmer
                      HS 3, HSPhone
                        #56
                        3.0.0.57
                        * Download xml files
                        Added feature to select any of the schedules to save a backup of the xml file that is downloaded. Save directory is data\weatherXML\backup
                        Go to the Schedules page and click the checkbox labeled Save Backup.
                        * Location Updates
                        Fixed the forecast text update to not update with a blank string. Builds a default forecast string with the temp, wind and precipatation values.
                        Fixed the import for Weather Underground to look for the error message when the xml download times out.
                        Added Count total for WU download errors in the xml file.
                        * Speak Devices
                        Added a speak device variable for the PHLocation City from the Follow Me feature.
                        Fixed an error where the Speak Devices Move Up/Move Down buttons were not displaying correctly.
                        * NOAA Alerts
                        Added more options to the Alert Triggers.
                        Alert Name Contains
                        Alert Name Not Contains
                        Alert Title Contains
                        Alert Title Not Contains
                        Alert Summary Contains
                        Alert Summary Not Contains
                        Jeff Farmer
                        HS 3, HSPhone
                          #57
                          3.0.0.58
                          Devices
                          * Fixed bug that was not following the setting for rounding the current rain totals. Rain Last Hour and Rain Today.
                          Jeff Farmer
                          HS 3, HSPhone
                            #58
                            3.0.0.59
                            Fixed error with the rounding of the rain values.
                            Jeff Farmer
                            HS 3, HSPhone
                              #59
                              3.0.0.60
                              * Download XML Files
                              Fixed the download to not continue with the import when the xml file did not download correctly.
                              Jeff Farmer
                              HS 3, HSPhone
                                #60
                                3.0.0.61
                                * Images
                                Fixed error with downloading a Google image when the submitted data has a comma in the numbers.
                                Jeff Farmer
                                HS 3, HSPhone
