Release Info for weatherXML for HS3
This topic is closed.
    #61
    3.0.0.63
    Random integration
    * IMPORTANT NOTE.
    If you are using both weatherXML and Random plugins.
    weatherXML had a public function that was the same name as one of HS3's functions. I have renamed the function. Random was using that function to get a list of available weatherXML variables so you must update both. Random 3.0.0.0 goes with weatherXML 3.0.0.63
    Images
    * Added code to not allow setting a replacement image for the curcond images
    Installation
    * Modified the install to put the dll files in the bin directory instead of the Bin directory. The install now matches the HS3 SDK on which directory is correct.
    Admin Pages
    * Removed the Speak Items page. The old style of speak Items no longer work. All speaking is now handled via the speak devices.
    Misc Maps
    * Added a warning if the size of the images exceeds the allowed maximums.
    Devices
    * Added Status Value graphics to the HSTouch Barometer Direction device. Uses new png versions of the direction images.
    * Added Status Value graphics to the HSTouch Wind Direction devices. Uses new png versions of the direction images.
    Jeff Farmer
    HS 3, HSPhone
      #62
      3.0.0.64 (Beta Release)
      * Added a setting to control how many of the backup files to keep. Oldest ones are deleted as new ones are saved.
      * Fixed a bug with the download backup that was saving the wrong file for the Alerts backup.
      * The map rotation device option is now hidden until at least one map has been setup.
      * Added setting to allow selecting which locations will create Global Variables.
      * Now tracks the device refIDs based on actual devices instead of storing the refID in an ini file.
      * Added the ability to set an image width or height for display on the weatherXML users Map page.
      * Added the ability to resize a downloaded Map image
      * Fixed the Event device references to work correctly
      * Fixed the PHLocation dropdowns to use the Location 1 first setting. <!-- / message --><!-- sig -->
      Jeff Farmer
      HS 3, HSPhone
        #63
        3.0.0.68 (Beta release)
        * More changes to the functions for standardizing the device addresses.
        * Fixed an issue with the image rotator device that would not display the dual image from NOAA correctly.
        Jeff Farmer
        HS 3, HSPhone
          #64
          3.0.0.69 (Beta Release)
          Fixed Map Rotation device to use the new name format for Radar image.
          Fixed bug where the Map Rotation device was not incrementing correctly
          <!-- / message -->
          <!-- controls -->
          Jeff Farmer
          HS 3, HSPhone
            #65
            3.0.0.70
            * Releasing Beta version 3.0.0.69 as Release version 3.0.0.70
            Jeff Farmer
            HS 3, HSPhone
              #66
              3.0.0.71
              Maps
              * Radar is now saved as Radar_1.gif and a second copy with the date in the name to prevent caching in HSTouch.
              Location Page
              * The Database link on the schedule page no longer shows when no location is set to use an Access database.
              * Add a time format dropdown to the location setup
              Tide Information
              * Added Tide Information devices. Setup is on the HSTouch tab but can be used anywhere that you want to display the information.
              * Tide information is no longer stored in an ini file. It is stored in the device plugin extra data.
              Misc Devices
              * The Last Spoken Log device now has a weatherXML tab that displays all of the current log entries
              Jeff Farmer
              HS 3, HSPhone
                #67
                3.0.0.72
                * Fixed an error that was not downloading the radar image unless you setup both the normal and non cache name.
                * Fixed an error when switching from Cumulus File to a different provider the Scheduled does not change from File Watch
                * Alert global variables are now set before the alert trigger
                * Added code to add the Moon Phase Status Graphics and the Wind Direction Status Graphics
                <!-- / message -->
                <!-- controls -->
                Jeff Farmer
                HS 3, HSPhone
                  #68
                  3.0.0.73
                  * Removed code that produces the weatherXML javascripts that are in the html/weatherXML directory. These were left over from HS2 and do not work with HS3.
                  * Fixed issue where the documentation pdfs were not loading.
                  * Humidity Device is now updating.
                  * Fixed error causing some of the maps to not build the Device Status Graphics correctly.
                  <!-- / message -->
                  <!-- controls -->
                  Jeff Farmer
                  HS 3, HSPhone
                    #69
                    3.0.0.74
                    * No longer using an ini file for maps.
                    * The Map Schedule is set by location, instead of just one schedule does all locations.
                    * The Map Group parent device now has buttons to add a new map and to Update Group Maps.
                    * The forecast devices now replace the wind direction abbreviations with the full spelled out text. Ex SW - South west
                    * The Map Group parent device has a setting to control which directory the maps are downloaded to. The directory must be under the images\weatherXML directory.
                    * Added the ability to sort the order of the maps on the user map page.
                    * No more confusing Download and Device checkboxes. All maps are now devices. The download is controlled by the entered URL.
                    * Added Logging Level to Event Actions. You can now set Event actions to set logging level to Debugging, Do a download and import, set logging level back to Errors.
                    * Temperature devices in the HSTouch Daily Group now create a Status Graphic for each 10 degree range from -100 to 100 giving the ability to use the Satus graphic in HSTouch and have the thermometer icon change to match the temperature.
                    Jeff Farmer
                    HS 3, HSPhone
                      #70
                      3.0.0.75
                      * New Script to import maps that were missed due to a setting value missing or a map not set to use a device.
                      Jeff Farmer
                      HS 3, HSPhone
                        #71
                        3.0.0.76
                        * Beta release of the alpha changes for .74 and .75
                        Jeff Farmer
                        HS 3, HSPhone
                          #72
                          3.0.0.76
                          * Release version of the changes for .74 and .75
                          Jeff Farmer
                          HS 3, HSPhone
                            #73
                            3.0.0.77
                            * Added option to select the number of places to round the UV total.
                            * Added to forecast: Precipitation Day Forecast, Night Forecast, and Total Day + Night Forecast available in inches or millimeter.
                            * Added Historical data: Rain totals for any of the past 7 days. Accumulated Rain Totals for past 7 days.
                            * Setup for the new precipitation devices is on the HSTouch\ Data Values Devices admin page.
                            Jeff Farmer
                            HS 3, HSPhone
                              #74
                              3.0.0.78
                              * New Event Action: Update Specific Map - This allows you to update a specific map more often then updating every map in a location.
                              Jeff Farmer
                              HS 3, HSPhone
                                #75
                                3.0.0.79
                                * Fixed an error that caused the support page to not always load.
                                Jeff Farmer
                                HS 3, HSPhone
