* Alert Conditions in events will trim the spaces on start and end of a condition.
* Added CURL as an option for Windows XP users using NOAA. Used for Alerts and Forecasts.
* Added Date Check for WU forecast to not import a forecast with a non current date. (WU Users)
Jeff Farmer
HS 3, HSPhone
* Fixed error where the "Use CURL" option was not saving the setting. (Only needed for those using Windows XP to run HomeSeer.)
* Fixed error: importForecastHourly: Input string was not in a correct format.
* Fixed error where the Media file play before and play after in alert triggers could not be cleared.
* Add the last update time as a device and variable for conditions. (Forecast will be in the next release.)
* Add the StationID as a device for WU and NOAA
* Windows XP Users only - Added the downloading of images from NOAA to work using CURL.
Jeff Farmer
HS 3, HSPhone
3.0.1.6
Changed error messages to replace the actual API key for the word API in the Logs.
Fixed error with Wind Units on the Cumulus File import
Fixed error converting the values when a comma is the decimal separator.
Jeff Farmer
HS 3, HSPhone
3.0.1.7
Changed code to lower case the updater_override.txt file name.
Fixed error where precipitation percent was not getting set to the correct value for those that use a comma for the decimal separator.. Ex. .10 vs ,10
Add Wind Gusts to the Forecast devices for provider DarkSky
Speak Devices: Modified the Forecast Day N to be a textarea instead of a textbox.
Note: The folowing does not affect existing Devices. Only as you add new devices.
Once a device is created you can change any of the location values and the device name. All the code uses the refID to make changes.
Devices with a location of "weather Forecast" will now be set to "weather Forecast Legacy"
Devices with a location "weather Current" will now be set to "weather Current Legacy"
Devices with a location "HSTouch Forecast" will become "weather Forecasts"
Devices with a location "HSTouch Current" will become "weather Conditions"
Jeff Farmer
HS 3, HSPhone
* Forecast Horizontal and Vertical using html code has been added back to Legacy devices.
* The forecast Day Name is now text in the Status Graphic tab. Once the forecast Day Name devices have been created you can edit the text for each day of the week. Do Not Change the Values, only the text.. 0 = Sunday, 1 = Monday, etc.
* Fixed error where the Forecast Day Rotator Device had a blank dropdown.
* To get a list of Devices that are not supported by the locations selected data provider, find the root device for the non Legacy conditions or Forecast group. Click on the device name to get to the Device Status section. Click on the weatherXML tab and if there are any devices not supported, there will be a list along with a button that when clicked will delete the unsupported devices.
Jeff Farmer
HS 3, HSPhone
3.0.1.8 Release Version
Submitted to the HS updater this morning.
* Added Cloud Cover as a condition device. It's value is a percentage.
* Fixed the function that determines if an alert matches a trigger. A value in the NOT columns was causing no matches.
* Fixed the Alert summary to pull the full text for an alert instead of only having a small portion of the alert.
* Added the text for any alert Instructions if available for the alert.
* The Alert Instruction text has been added to the trigger page and is available for speaking, emailing, or Pushover text (Pushover Plugin required).
* Fixed bug that cause a location to not download the json file.
Jeff Farmer
HS 3, HSPhone
