How To: Use a Random Phrase with weather Alert messages.
This topic is closed.
This is a sticky topic.
  • How To: Use a Random Phrase with weather Alert messages.
    Currently, the weather alerts only work for NOAA which provides alerts only for those in the U.S.
    I am looking into other sources for weather alerts outside of the U.S.
    Later this week, a new version of weatherXML will have a new variable to be used for weather Alerts if you are using both weatherXML and Random Phrase.
    #alertRandom#
    1. Create a new Category in Random Phrase. You can crate as many categories as you want. For example if you have a weather trigger for Tornadoes and a trigger for Thunderstorms, then you could create a category for Tornadoes and a category for Thunderstorms.
    2. Enter some phrases that you want to use for alerts.
    Ex.
    Attention! This is not a test. There is a weather alert.
    You attention please. I have a serious announcement.
    Coming to a county near you...
    3. In weatherXML, edit an Alert Trigger. There will be a dropdown that has all of the Random Categories to select from.
    4. Choose the Category that you created in stop 1.
    5. Edit the Speak Text and/or the Email Body text and use the variable #alertRandom#.
    6. The next time an alert triggers, it will replace the variable with one of the Phrases you entered in Step 2.
    Jeff Farmer
    HS 3, HSPhone
