Tides Information
  • #16
    I use tides near me and scrape the relevant information using Jon00's Datascraper script. Works great!
    • #17
      There is a script called World Tides which works well. See:
      https://forums.homeseer.com/forum/de...tides?t=158143
      • #18
        Thanks jono and will40. I had seen these approaches and I have been using the Datascraper for a different purpose. However, I wanted to display the information on the tides on my HSTouch homepage. Do you know how I could do this? Elliott
        • #19
          sorry, I'm not an HSTouch user. But I would think once you have a device with the tide info in it there are people who know how to get that to show up on HSTouch.
          • #20
            As noted above, "https://www.worldtides.info/" exists and they have an API.... so, somebody like CFGuy could probably add that to weatherXML..... [hint, hint, nudge, nudge...]
            Enabled Plug-Ins:
            • #21
              Thanks. The issue with the data from Datascraper is that no devices are created.
              • #22
                Thanks. There is presently a Tides option in WeatherXML. However, it appears to be through Weather Underground, which is a problem presently.
                • #23
                  You are doing something wrong then
                  Jon
                  • #24
                    Jon is absolutely correct! I do have devices for the scraped data. I was just looking in the wrong place for the devices.
                    • #25
                      Yep. I was using it until WU crashed and burned.
                      Enabled Plug-Ins:
