realtime.txt online?
    Hi Jeff,
    I'm guessing that since I'm not getting any data, WeatherXML doesn't pull realtime.txt from online? I don't use Cumulus but I can massage my MeteoBridge to create a realtime.txt file. Does it have to be on a local drive?
    Cheers!
    Chris
    It is designed to watch a local or mapped folder. That way anytime the file changes it gets imported.
    I can add to my to do list to have it grab the file every x number of minutes instead of watching a directory.
    Jeff Farmer
    HS 3, HSPhone
      Before you spend too much time on it Jeff, let me do some work with MeteoBridge to see if I can get the file dropped to a mapped drive. I'll let you know how I fare.
      Cheers!
      Chris
        Hi Jeff,
        I have figured a way to have the file appear in a local drive so no need to make that change on my account. Thanks for looking into it though.
        Cheers!
        Chris
          Here utilize two weatherstations in two geographical locations. Both upload to a hosting service such that I download the realtime txt file for each site and rename it with this script.
          Sub Main(ByVal Parm As Object)
                  Dim FileSource As String = "http://www.rideauwx.info/realtime.txt"
                  Dim FileDestination As String = hs.GetAppPath & "\config\realtime-rideauwx.txt"
                  If System.IO.File.Exists(FileSource) Then
                      System.IO.File.Copy(FileSource, FileDestination)
                  Else
                      hs.WriteLog("Error", "Cannot access Realtime.txt")
                  End If
             End Sub
          - Pete
          Auto mator
          Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
          HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
          HS4 Lite -
            Looking at my stuff changed it to one liners for the two sites via a bash script and cron job.
            #!/bin/sh
            lynx --dump hxxp://hostip/weather-1/realtime.txt[/url] > /HomeSeer/Config/lockport.txt
            lynx --dump hxxp://hostip/weather-2/realtime.txt[/url] > /HomeSeer/Config/longboatkey.txt
            - Pete
            Auto mator
            HS4 Lite -
              Very cool. Running in a Windows box but I've been using a replacement command processor, called Take Command (started out as 4DOS), for years now. Cooked up a batch file to download the file every 10 minutes. Posting this from my phone so I can't show you the code right now. I'll post it here when I get home if I think of it.
              For anyone who wants to have a boo, jpsoft.com will let you d/l a 30 day trial of Take Command. Very powerful batch language.
              Cheers!
              Chris
                Remembered I meant to post this. It is definitely not elegant, but it does work. I run it in a TCC window. Eventually I will massage it to write to the Homeseer log if that is possible... shouldn't be too hard I don't think.
                @echo off
                Rem getRealtime.btm
                Rem by Chris Grainger
                Rem Running under TCMD 19.10
                Rem Created to allow automation system access to realtime.txt on a timed basis
                Rem February 22, 2016 - Initial
                Rem March 2, 2016 - Edits for midnight problem... delay until 00:00:00 doesn't
                Rem                         work without a date.
                Rem Download 'realtime.txt' from remote directory every 10 minutes
                Rem on the 10's.  Assumes batch file is running in the directory where
                Rem you want the file downloaded.
                Rem Start ftp session with iftp and make 'rideauwx' the default
                Rem remote directory.
                iftp "ftp://Your_ftp_username:Your_FTP_password@Your_FTP_site/directory"
                Rem Initialize some variables
                	set hr=%_hour
                	set min=%_minute
                Rem Start the forever loop
                cls
                do forever
                	Rem Start a loop to time the downloads for every 10 minutes on the 10
                	do i=0 to 60 by 10
                		Rem Start at the nearest next 10 minute mark
                		if %i LT %min iterate
                		Rem zero pad any single digit minute to two digits
                		set t=%@formatn[02.0,%i]
                		Rem Test for Top of hour and for midnight
                		iff %t GE 60 then
                			set t=%@formatn[02.0,0]
                			set hr=%@formatn[02.0,%@eval[%_hour + 1]]
                			iff %hr EQ 24 then
                				set hr=23
                				set t=59
                			endiff
                		endiff
                		echo Next download at %hr:%t:00
                		delay until %hr:%t:00
                		Rem Copy the file via ftp.  Is Bluehost doing something  to time?
                		Rem Have to touch the file to set correct time.
                		copy /q ftp:realtime.txt
                		touch /q realtime.txt
                                    echo realtime.txt downloaded at %_hour:%@formatn[02.0,%_minute]
                		Rem Add 10 minutes to get next download time
                		set min=%@formatn[02.0,%@eval[%_minute + 10]]
                		iff %min GE 60 then
                			set min=%@formatn[02.0,0]
                			iff %hr EQ 24 then
                				set hr=%@formatn[02.0,0]
                				delay 70
                			endiff
                		endiff
                		echo.
                	enddo
                  Here I think its just related to using Linux and methodology of read of realtime.txt file.
                  - Pete
                  Auto mator
                  HS4 Lite -
                    Hi Jeff,
                    Cheers!
                    Chris
                    Hi Chris - sorry for bumping an old thread but I'm trying to do the exact same thing as you with my new Meteobridge PRO and could use some help. Would you mind explaining how you configured your meteobridge to export a properly formatted realtime.txt file? I don't see realtime.txt as an option in the export templates and I'm struggling to figure this out. Any help would be appreciated.
                    Thanks in advance!
                    Dom
                      Thanks in advance!
                      Dom
                      Hi Dom,
                      MeteoBridge Pro, eh? I was tempted.... couldn't justify the cost and bought a 2-year extension to my MeteoBridge licence instead. maybe in a couple of years...
                      To answer your question, here's the code I use in realtime-template.txt
                      [DD]/[MM]/[YY] [hh]:[mm]:[ss] [th0temp-act] [th0hum-act.0] [th0dew-act] [wind0avgwind-act] [wind0wind-act] [wind0dir-act.0] [rain0rate-act] [rain0total-daysum] [thb0seapress-act] [wind0dir-act=endir] [wind0wind-act=bft.0] m/s C hPa mm 0.0 [thb0seapress-val60:--] [rain0total-monthsum] [rain0total-yearsum] [rain0total-ydaysum] [thb0temp-act] [thb0hum-act.0] [wind0chill-act] [th0temp-val60:--] [th0temp-dmax] [th0temp-dmaxtime.ij]:[th0temp-dmaxtime.kl] [th0temp-dmin] [th0temp-dmintime.ij]:[th0temp-dmintime.kl] [wind0avgwind-dmax] [wind0avgwind-dmaxtime.ij]:[wind0avgwind-dmaxtime.kl] [wind0wind-dmax] [wind0wind-dmaxtime.ij]:[wind0wind-dmaxtime.kl] [thb0seapress-dmax] [thb0seapress-dmaxtime.ij]:[thb0seapress-dmaxtime.kl] [thb0seapress-dmin] [thb0seapress-dmintime.ij]:[thb0seapress-dmintime.kl] [mbsystem-swversion:--] [mbsystem-buildnum:--] [wind0wind-max10] [th0heatindex-act:--] [wind0chill-act:--] [uv0index-act:0.0] 0.0 [sol0rad-act:0] [wind0dir-avg10.0:--] [rain0total-sum60] [forecast-rule] [mbsystem-isday.0] 0 [wind0dir-avg10=endir] 0 m 0.0 [mbsystem-daylength] 0 0
                      Setting up my Meteobridge like so,
Name:	Realtime Setup Meteobridge.JPG
                      gets me a realtime.txt every minute. I should note that I have a Vantage Vue and no solar sensor, hence the hard coded zeros for some of the data.
                      I *think* that the Pro uses the same tags as MeteoBridge, so this should work for you as well.
                      Hope that helps.
                      Cheers!
                      Chris
                      Last edited by chrisgrainger; June 19, 2017, 03:49 PM. Reason: Adding comment re tags on the Pro
                        Hey Chris thanks for the quick response. Yeah I really hemmed and hawed about getting the pro and just bit the bullet :-)
                        I'm still learning the device, but if I'm reading your settings correctly, then you are reading the template file from the http location (I assume that's your site?) and then the MB sends a realtime.txt file to an FTP site in the rideauwx/ directory?
                        On the pro there is a separate screen to configure the FTP hostname/credentials, etc - so I assume that's the case for you?
                          Hey there,
                          Yup, you upload the template to your site once. Then Meteobridge uses that template, every time period you set, to upload the specific data that you've set in the template. It winds up in a realtime.txt file. In Meteobridge, the FTP setup is at the bottom of the Services page and looks like this.
                          Sounds like Boris moved that to it's own page on the Pro. Once you get it set up, Meteobridge does it's thing and you can use that realtime.txt in any software that knows about it.
                          Like so....
                          20/06/17 13:31:46 21.8 68 15.6 4.0 3.1 245 0.0 0.8 1008.9 WSW 2 m/s C hPa mm 0.0 1009.0 46.2 490.8 6.0 27.0 50 21.8 21.6 22.7 13:04 16.1 06:07 4.0 11:32 7.2 11:00 1009.4 11:14 1006.0 02:35 3.2 11222 7.2 21.8 21.8 0.0 0.0 0 237 0.0 192 1 0 WSW 0 m 0.0 15:35 0 0
                          Cheers!
                          Chris
                            OK I think I figured it out, thanks so much for your help!
                            I have a local FTP server (on my NAS) and I've successfully been FTPing the realtime.txt file to it every minute. The PRO has local storage which can be shared via SMB so it would be nice to be able to dump the realtime.txt file to that local storage instead of having another network device in the mix (another point of failure, etc). If that's not possible, then I might just install an FTP server on my HS3 machine and point it there. But I'll take that question over to the Meteobridge forum :-)
                            Thanks again Chris you've been very helpful!
                            Cheers, Dom
                              Cheers, Dom
                              I thought of that... running an FTP server on my HS3 machine... but, AFAICS, you can't have more than one FTP account set up on Meteobridge. And that would kill stuff I have going on with my weather website.
                              Can the Pro be set with more than one FTP account?
                              Chris
