WeatherXLM update 3.0.0.42
    Thank you for the update Jeff.
    Just an FYI relating to update 3.0.0.42.
    Just noticed when it is enabled it disables my hourly chime event.
    Previous version of WeatherXML did not do this.
    I was running HS3 Pro V.218 on Ubuntu 14.04 64 bit.
    I noticed after the update that my hourly chime event wasn't triggering.
    Other reoccurring events worked fine.
    I would disable the plugin and the hourly chime event would work then.
    Today updated HS3 Pro to V.245, enabled the plugin and my hourly chime did not work. I then disabled the plugin and the hourly chime worked.
    Could it be due to the errors / events running in WeatherXML (Linux version)?
    - Pete
    Auto mator
    HS4 Pro - V4.1.3.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
    HS4 Lite -
    What errors are you seeing in the log?
    Jeff Farmer
    HS 3, HSPhone
      Same as in V.41.
      Downgraded today to V.41.
      Just copied over the exe v.41 file overwriting the exe v.42 file.
      Note here guessed on why my hourly chime quite working in HS3 for Linux V.218. Disabled the weatherXML plugin V.42 and it started to work again.
      Now at V.41 and will validate that the chimes are working and weatherXML is concurrently running.
      Here are the weatherXML logs. (do not have debug running). Same stuff in logs for .42 as in .41 as in .40. I think that it is all relating to reading the realtime.txt file from Cumulus.
      It is configured as:
      Pathway to Cumulus File #1
      /HomeSeer/Config/lockport.txt
      28/02/16 09:49:28 55.2 66 44.0 14.5 9.0 144 0.00 0.00 29.566 SE 4 mph F in in 10
      0.2 -0.018 0.58 1.23 0.00 65.5 50 55.2 +3.0 55.2 09:47 41.8 01:41 17.6 08:32 30.
      0 07:46 29.787 00:00 29.566 09:49 3.0.0 3037 24.0 55.2 55.0 0.0 0.000 0 157 0.00
      24 1 0 SSE 2537 ft 45.7 0.0 488 0
      On the local Cumulus server realtime.txt file looks like this before it is FTP'd to the host server on the internet.
      28/02/16 10:55:28 58.3 64 46.2 21.9 19.0 162 0.00 0.00 29.527 SSE 5 mph F in in 120.8 -0.029 0.58 1.23 0.00 65.6 50 58.3 +3.0 58.4 10:41 41.8 01:41 21.9 10:55 36.0 10:07 29.787 00:00 29.527 10:53 3.0.0 3037 34.0 58.3 58.9 0.0 0.000 0 162 0.00 24 1 0 SSE 2756 ft 45.1 0.0 609 0
      Pathway to Cumulus File #2
      /HomeSeer/Config/longboatkey.txt
      28/02/16 11:04:15....
      Downloading realtime text file using a cron job and a bash script these days.
      #!/bin/sh
      lynx --dump hxxp://hostip/weather-1/realtime.txt[/url] > /HomeSeer/Config/lockport.txt
      lynx --dump hxxp://hostip/weather-2/realtime.txt[/url] > /HomeSeer/Config/longboatkey.txt
      I can test again updating to V.42 with debug on to get granular with it if you want?
      Feb-28 10:26:12 AM 	  	weatherXML 	Reset provider counts
      Feb-28 10:27:01 AM 	  	weatherXML Error 	importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
      Feb-28 10:27:01 AM 	  	weatherXML Error 	device Wind Speed: Conversion from string "30. 0" to type 'Double' is not valid.
      Feb-28 10:27:01 AM 	  	weatherXML Error 	setDeviceUVObject reference not set to an instance of an object
      Feb-28 10:28:01 AM 	  	weatherXML Error 	importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
      Feb-28 10:28:01 AM 	  	weatherXML Error 	setDeviceUVObject reference not set to an instance of an object
      Last run of hourly chimes was before downgrade and with WeatherXML at V.42
      Play Hourly Chime Last Ran: Today 10:00:03 AM
      Manually ran it just now with WeatherXML V.41 enabled.
      Feb-28 10:38:44 AM Event Event Chime Play Hourly Chime triggered by the event page 'Run' button.
      Feb-28 10:38:44 AM Event Event Trigger "Chime Play Hourly Chime"
      Waiting now to see if it runs on the hour in around 20 minutes.
      Update 1105 C
      Hourly chime did not work this time with my downgrade to V.41 (just the exe file though).
      Updated back to V.42 and disabled WeatherXML plugin for time bean.
      Feb-28 11:01:02 AM 	  	weatherXML Error 	fixForecastStrings Day: The best match for method Set has some invalid parameter.
      Feb-28 11:01:02 AM 	  	weatherXML Error 	fixForecastStrings Night: The best match for method Set has some invalid parameter.
      Update 1509 C
      Hourly chimes have worked fine (with WeatherXML disabled).
      2/28/2016
      Feb-28 12:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-28 1:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-28 2:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-28 3:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Update 29th of Feb. 2016 - 1104C
      Last night downgraded to .41 the long way and enabled hourly chimes. The hourly chime is working fine now.
      Feb-29 8:00:03 AM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 8:01:47 AM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 10:00:03 AM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 11:00:03 AM Event Event Trigger "Chime Play Hourly Chime"
      Update 1st of March 2016. Hourly events continue to work fine with WeatherXML V3.0.0.41. I do not know today what changed from V.41 to V.42.
      2/29/2016
      Feb-29 12:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 12:22:27 PM Event Event Trigger "Client Speak Speak-13"
      Feb-29 12:22:30 PM Event Event Trigger "Client Speak Speak-13"
      Feb-29 12:22:38 PM Event Event Trigger "Client Speak Speak-13"
      Feb-29 1:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 2:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 3:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 4:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 5:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 6:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 7:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 8:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 9:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      Feb-29 10:00:03 PM Event Event Trigger "Chime Play Hourly Chime"
      3/1/2016
      Mar-01 8:00:03 AM Event Event Trigger "Chime Play Hourly Chime"
      - Pete
      Auto mator
      HS4 Lite -
