Thank you for the update Jeff.
Here running HS3 Pro V.258 and HSDesigner / Windows Clients V. 3.0.0.43 these days.
Not testing the speaker dot exe stuff at this time and will do that shortly.
Along with the Wintel touchscreen clients I am also using MS SAPI speech fonts per each client these days via Speaker dot exe.
Base now is 15-20 Wintel HSTouch clients. 15 are running in XPe and all doing well.
Speaker ICS-HS3 (192.168.244.171) : ICS-JOG-XPE-01 ==> ICS-JOG-XPE-15 plus W7, W10 and HS3 Wintel VB W2003 clients.
Looking at the logs this morning I do not see any Cumulus files issues.
This is all I see right now which is good and not much of an issue.
Mar-13 9:00:03 AM Event Event Trigger "Chime Play Hourly Chime" Event_13-Mar-2016 09:00:03.39098816_Play Hourly Chime
Mar-13 9:01:03 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
Mar-13 9:01:04 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
It is understood that you will be getting to the sqlite issues shortly.
Mar-13 6:01:03 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
Mar-13 6:01:04 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
Mar-13 6:51:54 AM weatherXML Error SQLite.Interop.dll
Mar-13 6:51:54 AM weatherXML Error runSelectQuery: SQLite.Interop.dll
The animated GIF files on my Wintel HSTouch screens work well now with the updated Windows HSTouch V.43 these days via direct links.
