Hi and Low Temp just current day's actual.
  • Hi and Low Temp just current day's actual.
    Hi, I'm tring to display the current day's high and low temp in Imperihome.
    I'm using the current location's:
    • LocationX Hi Temp
    • LocationX Low Temp
    However, these values only show the current hi or low reached for that day, not the forecasted hi value.
    The result is the "hi" is just the current temp reached for the day (normally from the early morning). How can I get the FORECASTED max hi temp of the day.
    To get the forecasted hi and low, use the devices on the HSTouch tab. Select the Forecast Day 0 High and Low.
    Jeff Farmer
    HS 3, HSPhone
      The two X out in the screenshot are having the symptom I described. The high is only the highest temp reached that day, not the max high forecasted for the day.
      The Today forecast provides text, not a # value (i.e. 78). The variable text I get for the circled device is:
      Partly cloudy. High 68. wind's West Northwest at 5 to 10 miles per hour.
      Screenshot of my settings:
      https://onedrive.live.com/redir?resi...nt=photo%2cPNG
        Nevermind, your HS Touch trick worked great from the other post.
        Mucho thanks!
          Look at the menu items.
          You are on the page labeled Devices. I am saying to use the one that is to the right of Devices. It is labeled HSTouch.
          If you use the ones in the current section, then yes, it is the current at this moment, so far today, max high and low.
          If you scroll down to the Forecast section, and select Day 0: Today, High and Low it will be what you are wanting.
          Jeff Farmer
          HS 3, HSPhone
            Mucho thanks!
            Cool. Glad you got the values you wanted.
            Jeff Farmer
            HS 3, HSPhone
