Possible mistake in my settings.
  • Possible mistake in my settings.
    Hello
    I am struggling to setup my weather xml plug in.
    I intend to add devices so I can create a custom weather screen in HSTouch without the RSS Feeds.
    I have setup my account with WWO and it has given me a premium 60day trial API.
    My LAT is 54.00
    My Long is -2.78
    UK
    I have my API in the LOCATION settings with my LAT and LON.
    Please can you advise?
    On the schedules page are you getting run times?
    Jeff Farmer
    HS 3, HSPhone
      Also check in the HomeSeer HS3/Data/weatherXML directory for a file called WWConditions1.xml.
      Is there any data in the file?
      I'm headed out to work but will check back when I get off.
      Jeff Farmer
      HS 3, HSPhone
        Hi
        My schedule is set up like yours but 30 minute intervals.
        I checked the directory; the only data file I have is weatherXML.mdb
        Nothing else?
          If you don't have any xml files in the data directory, then the downloads are not running.
          At the top of the schedules page where it says Schedules Status that there is a message "All active will run".
          Set the logging level to Debug on the Settings page. Then go to the schedules page and click the Run Now button. Check the HS log for any error messages.
          Jeff Farmer
          HS 3, HSPhone
            I got the same problom.
            My log is telling me this
            Jun-04 2:16:08 AM weatherXML The C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\WWConditions1.xml file is missing. Unable to continue the data import.
            Jun-04 2:16:08 AM weatherXML Download Status: Failure
            Jun-04 2:16:08 AM weatherXML Error downloadFile: WWO Weather from: http://api.worldweatheronline.com/fr...c0151220162905. Error: System.Net.HttpWebResponse The remote server returned an error: (403) Forbidden.
            Jun-04 2:16:08 AM weatherXML Downloading the WWO Weather file at http://api.worldweatheronline.com/fr...c0151220162905.
            Jun-04 2:16:07 AM weatherXML Downloading the WWO Weather file at http://api.worldweatheronline.com/fr...c0151220162905
              Jun-04 07:40:00 weatherXML Check timer items
              Jun-04 07:39:00 weatherXML Check timer items
              Jun-04 07:38:57 Z-Wave Device: Z-Wave Ensuite Temperature Set to 25.8 (C)
              Jun-04 07:38:00 weatherXML Check timer items
              Jun-04 07:37:20 weatherXML Check Condition Triggers
              Jun-04 07:37:20 weatherXML World Weather Online Current Conditions Finished
              Jun-04 07:37:20 weatherXML Output XML
              Jun-04 07:37:20 weatherXML Create Image
              Jun-04 07:37:20 weatherXML Check to see if DB is being used. Save the data is set to Yes.
              Jun-04 07:37:20 weatherXML The speakID was not a valid choice: 0
              Jun-04 07:37:20 weatherXML Build custom speak string
              Jun-04 07:37:20 weatherXML Finished running weatherXML Speak
              Jun-04 07:37:20 weatherXML weatherWind: wind
              Jun-04 07:37:20 weatherXML Get Hi/Low Temp
              Jun-04 07:37:20 weatherXML weatherTemp: current
              Jun-04 07:37:20 weatherXML weatherUpdated:
              Jun-04 07:37:20 weatherXML Found items set to speak. Proceed
              Jun-04 07:37:20 weatherXML Look for any items set to speak.
              Jun-04 07:37:20 weatherXML Location: 1
              Jun-04 07:37:20 weatherXML Build main speak string
              Jun-04 07:37:20 weatherXML The C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\WWConditions1.xml file is missing. Unable to continue the data import.
              Jun-04 07:37:20 weatherXML Download Status: Failure
              Jun-04 07:37:20 weatherXML Error downloadFile: WWO Weather from: ://api.worldweatheronline.com/free/v2/weather.ashx?q=54.04,-2.89&format=xml&includeLocation=yes&showmap=yes&num_of_days= 5&tp=12&key=myapikeyishere. Error: System.Net.HttpWebResponse The remote server returned an error: (403) Forbidden.
              Jun-04 07:37:19 weatherXML Downloading the WWO Weather file at ://api.worldweatheronline.com/free/v2/weather.ashx?q=54.04,-2.89&format=xml&includeLocation=yes&showmap=yes&num_of_days= 5&tp=12&key=myapikeyishere.
              Jun-04 07:37:19 weatherXML Download and Import
              Jun-04 07:37:19 weatherXML Reset Hi Low
              Jun-04 07:37:19 weatherXML wXMLCurrent: Running current location 1
              Jun-04 07:37:01 weatherXML page: weatherXML_config, data: &id=menuTopSettings&menuTopSettings=Submit
              Jun-04 07:37:00 weatherXML Check timer items
              Jun-04 07:36:00 weatherXML Triggers to check: 0
              Jun-04 07:36:00 weatherXML Check for last ran triggers
              Jun-04 07:36:00 weatherXML Check timer items
              Jun-04 07:35:00 weatherXML Check timer items
              I removed the http to prevent the forum making it a url and have hidden my api key
              It is looking like a common problem then if Tvins81 has the exact same issue.
                The problem is that the free key URL no longer works for new users.
                That's why you see "The remote server returned an error: (403) Forbidden." in the logs.
                My understanding was that it was supposed to stay working for former users. I will test that this weekend to make sure.
                For those with the new premium key the URL is different. I need to add a way to allow selecting which type of key you have.
                In the meantime, follow this post.
                http://forums.homeseer.com/showpost....75&postcount=5
                Jeff Farmer
                HS 3, HSPhone
                  Sorry, but i had only change the v1.. You need to change premium/v1 and it works.
                    Jeff where do you want me to add the key....?
                    [wwoCommon]
                    wwoRegister=http://www.worldweatheronline.com/register.aspx
                    wwoDownloadURLC1=http://api.worldweatheronline.com/premium/v1/weather.ashx?q=
                    wwoDownloadURLC2=&format=xml&num_of_days=5&key=
                    [CurrentLocations]
                    city1=Default
                    [WeatherInfo1]
                    xmlSource=wwo
                    useForecast=1
                    wwoLat=54.04
                    wwoLon=-2.89
                    wwoAPIKey=3df2cac....key is here?
                    even with the above, switching off/on the plugin and restarting, I still get in my log:
                    Jun-04 23:16:09
                    weatherXML Error downloadFile: WWO Weather from: h##p://api.worldweatheronline.com/free/v2/weather.ashx?q=54.04,-2.89&format=xml&includeLocation=yes&showmap=yes&num_of_days= 5&tp=12&key=********mykey*****.
                      Follow this post.
                      You have this.
                      Which is a left over value from the last time that WWO changed their URL.
                      What you need to use is this.
                      wwoDownloadURLCur1=http://api.worldweatheronline.com/premium/v1/weather.ashx?q=
                      Note the ending of the key name is LCur1 instead of LC1.
                      Its easy to miss.
                      Jeff Farmer
                      HS 3, HSPhone
                        I feel proper silly.
                        All working, apart from
                        MoonPhase
                        Day 5
                        Day 6
                        Day 7
                          MoonPhase
                          Day 5
                          Day 6
                          Day 7
                          You won't get those with World Weather Online. MoonPhase is only provided by Weather Underground.
                          Also World Weather Online only provides a 5 day forecast, which is Day 0 (Today) to Day 4.
                          Jeff Farmer
                          HS 3, HSPhone
