Looks here like WeatherXML V.50 has been doing fine.
Thank you for providing us this Homeseer 3 plugin.
Recently been tweaking the alerts section and integrating it with the hard switch on the weather radio. Is it possible to manually run an alert look and see based on the weather radio hard switch? Or can I already do that with WeatherXML alerts look and see?
Still see a couple of issues.
This one I think has to do with WUN forecasts.
Aug-14 2:01:01 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
Aug-14 2:01:02 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
And the cumulus txt file read from way back.
Aug-14 2:06:00 AM weatherXML Error importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
Aug-14 2:06:00 AM weatherXML Error setDeviceUVObject reference not set to an instance of an object
Aug-14 2:06:01 AM weatherXML Error importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
Aug-14 2:06:01 AM weatherXML Error setDeviceUVObject reference not set to an instance of an object
Just recently switched to getting NOAA UV values from a text file that they post using Jon00's data scraper plugin.
I mix it a bit on and off with analog readings.
NOAA/EPA ULTRAVIOLET INDEX /UVI/ FORECAST
NWS CLIMATE PREDICTION CENTER CAMP SPRINGS MD
136 PM EDT SUN AUG 14 2016
And utilizing the NOAA UV index map here which I just automatically download with the weather map stuff.
and mix it with this one from the EPA.
Sqlite DB writing is doing well. Not sure if you ever looked at the mySQL DB writing stuff?
