WeatherXML V.51 in HS3 Pro Ubuntu 64bit
    Thank you Jeff for the update. I do see more base debug logging with the Cumulus stuff.
    Not really sure what is going on with that one client #9. I was sleeping.
    I do not even know where it is at but I do have them numbered (in the backs of them) so I could look today.
    All I do is disable the screens (no suspending these days). Wondering if it a wireless thing? Checking it was a wirelessly connected client. Rebooted it?
    Aug-16 3:49:17 AM HSTouch Server Client ICS-Jog-XPE-09 named ICS-Jog-XPE-09 has DISCONNECTED.
    Aug-16 3:49:42 AM HSTouch Server Opening connection from:192.168.244.224/4604
    Aug-16 3:49:43 AM HSTouch Server Client ICS-Jog-XPE-09 (192.168.244.224/4604) named ICS-Jog-XPE-09 has CONNECTED.
    Aug-16 3:49:43 AM HSTouch Server Connecting speaker client to HomeSeer IP 127.0.0.1
    Aug-16 3:49:43 AM Speaker Speaker host added, Name: ics-HS3 Instance: ICS-Jog-XPE-09 IP address: 192.168.244.171
    Aug-16 4:01:01 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
    Aug-16 4:01:02 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
    Aug-16 4:06:00 AM weatherXML Error importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
    Aug-16 4:06:00 AM weatherXML Error importCumulusFile Contents: 16/08/16 03:31:08 71.1 96 69.9 0.4 2.0 15 0.05 0.00 29.909 NNE 0 mph F in in 1.4 +0.009 0.24 12.50 0.23 69.7 50 71.1 0 71.1 00:00 71.1 00:00 0.4 00:00 2.0 00:00 29.909 03:29 29.871 01:45 3.0.0 3040 6.0 71.1 86.0 0.0 0.000 0 15 0.00 2 0 0 NN E 272 ft 78.5 0.0 0 0
    Aug-16 4:06:00 AM weatherXML Error setDeviceUVObject reference not set to an instance of an object
    Aug-16 4:15:00 AM Log Maintenance 376 records, selected by date/time, were removed from the log database.
    Aug-16 4:15:00 AM Log Info The log database is currently 15.7MB in size.
    Aug-16 5:01:02 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
    Aug-16 5:06:00 AM weatherXML Error importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
    Aug-16 5:06:00 AM weatherXML Error importCumulusFile Contents: 16/08/16 04:35:38 71.1 96 69.9 0.4 2.0 15 0.05 0.00 29.918 NNE 0 mph F in in 1.8 +0.013 0.24 12.50 0.23 69.9 51 71.1 0 71.1 00:00 71.1 00:00 0.4 00:00 2.0 00:00 29.923 03:44 29.871 01:45 3.0.0 3040 6.0 71.1 86.0 0.0 0.000 0 15 0.00 1 0 0 NN E 272 ft 78.5 0.0 0 0
    Aug-16 5:06:00 AM weatherXML Error setDeviceUVObject reference not set to an instance of an object
    Aug-16 5:28:18 AM HSTouch Server Warning Client dropped connection 255.255.255.255/0
    Aug-16 5:28:18 AM HSTouch Server Client ICS-Jog-XPE-09:ICS-Jog-XPE-09 (255.255.255.255/0) has raised LineDisconnected.
    Aug-16 5:28:18 AM Speaker Speaker host disconnected, Name: ICS-HS3 IP address: 192.168.244.171
    Aug-16 5:28:18 AM HSTouch Server Client ICS-Jog-XPE-09 named ICS-Jog-XPE-09 has DISCONNECTED.
    Aug-16 5:28:18 AM ASR Speaker Client speech recognition stopped
    Aug-16 5:28:43 AM HSTouch Server Opening connection from:192.168.244.224/4619
    Aug-16 5:28:44 AM HSTouch Server Client ICS-Jog-XPE-09 (192.168.244.224/4619) named ICS-Jog-XPE-09 has CONNECTED.
    Aug-16 5:28:44 AM HSTouch Server Connecting speaker client to HomeSeer IP 127.0.0.1
    Aug-16 5:28:44 AM Speaker Speaker host added, Name: ics-HS3 Instance: ICS-Jog-XPE-09 IP address: 192.168.244.171
    Aug-16 6:01:01 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
    Aug-16 6:01:06 AM weatherXML Error setForecastDataArray: The best match for method Set has some invalid parameter.
    - Pete
    Auto mator
    Set logging level to debug. Then when the cumulus file is imported grab the log entries.
    Also if you could, grab a screen shot of Devices Setup with the Current Conditions section.
    And then grab a screen shot of the HSTouch Devices setup with the Current Conditions section.
    Jeff Farmer
    HS 3, HSPhone
      Thank you Jeff.
      Will follow up with request.
      Here are repetitive log entries (which are similar to earlier stuff).
      Aug-23 5:01:01 AM 	  	weatherXML Error 	setForecastDataArray: The best match for method Set has some invalid parameter.
      Aug-23 5:06:00 AM 	  	weatherXML Error 	importCumulusFile: Operator '>' is not defined for type 'String' and type 'Int32'.
      Aug-23 5:06:00 AM 	  	weatherXML Error 	importCumulusFile Contents: 23/08/16 04:32:25 65.3 85 60.7 0.0 0.0 0 0.00 0.00 30.154 N 0 mph F in in 0.0 +0 .000 0.46 12.72 0.00 69.5 47 65.3 0 65.3 00:00 65.3 00:00 0.0 00:00 0.0 00:00 30 .157 00:49 30.142 00:05 3.0.0 3040 4.0 65.3 73.4 0.0 0.000 0 0 0.00 2 0 0 N 1051 ft 68.8 0.0 0 0
      Aug-23 5:06:00 AM 	  	weatherXML Error 	setDeviceUVObject reference not set to an instance of an object
      I've attached the Cumulus Barometer values seen. I do not see the value in weatherxml current weather status.
      My Cumulus / Davis Vantage Pro doesn't do UV such that the value is zero from Cumulus. I do pull down a UV value from NOAA every day.
      Debug log / cumulus section will be added or attached.
      - Pete
      Auto mator
