Loaded .53. Added a third location based on PHLocation data. But no additional devices appeared. Devices for Location 1 and 2 are present, but location 3 hasn't appeared. Is there a way to force the build/rebuild of devices for a newly added location?
Force Build/Rebuild Devices?
Last edited by Mr_Resistor; September 5, 2016, 12:44 PM.My home is smarter than your honor roll student.Tags: None
Adding a location doesn't add any devices. There is so many devices that can be added, that I decided to leave it up to the user.
When you are on the Locations page, click on the menu button labeled Advanced. Then click on the HSTouch menu button.
Make sure you select the correct location in the dropdown. Then just click the checkbox in front of the devices you want to use for that location.--
Jeff Farmer
HS 3, HSPhone
