Cache issue with current conditions?
    I am getting this odd error that every so often my current conditions revert back to 77 Degrees and winds at 6mph.
    This has been happening for about 2 or 3 weeks.
    Ideas on what might cause this? I did turn on debugging and it showed that data in the log coming from WU.
    11/10/2016 02:49 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:46 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:41 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:36 PM 58 58 51 1 Northwest 2 325 10 40 30.05 11 0 0 Clear
    11/10/2016 02:31 PM 58 58 51 1 Northwest 2 325 10 40 30.05 11 0 0 Clear
    11/10/2016 02:26 PM 58 58 51 1 Northwest 2 325 10 40 30.05 11 0 0 Clear
    11/10/2016 02:21 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:16 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:11 PM 77 77 63 6 South Southeast 0 163 10 63 30.05 11 0 0 Partly Cloudy
    11/10/2016 02:06 PM 59 59 51 3 North Northwest 5 328 10 40 30.05 11 0 0 Clear
    11/10/2016 02:01 PM 59 59 51 3 North Northwest 5 328 10 40 30.05 11 0 0 Clear
    11/10/2016 01:56 PM 59 59 52 1 North Northwest 2 329 10 41 30.08 11 0 0 Clear
    11/10/2016 01:51 PM 59 59 52 1 North Northwest 2 329 10 41 30.08 11 0 0 Clear
    11/10/2016 01:46 PM 59 59 52 1 North Northwest 2 329 10 41 30.08 11 0 0 Clear
    11/10/2016 01:41 PM 59 59 52 1 North Northwest 2 329 10 41 30.08 11 0 0 Clear
    11/10/2016 01:36 PM 58 58 52 0 West Northwest 5 291 10 40 30.08 11 0 0 Clear
    11/10/2016 01:31 PM 58 58 52 0 West Northwest 5 291 10 40 30.08 11 0 0 Clear
    11/10/2016 01:26 PM 58 58 51 0 Northwest 5 319 10 39 30.08 11 0 0 Clear
    11/10/2016 01:21 PM 58 58 51 0 Northwest 5 319 10 39 30.08 11 0 0 Clear
    11/10/2016 01:18 PM 58 58 51 0 Northwest 5 319 10 39 30.08 11 0 0 Clear
    11/10/2016 01:17 PM 58 58 51 0 Northwest 5 319 10 39 30.08 11 0 0 Clear
    11/10/2016 01:16 PM 77 77 63 6 South Southeast 0 163 10 63 30.08 11 0 0 Partly Cloudy
    11/10/2016 01:11 PM 77 77 63 6 South Southeast 0 163 10 63 30.08 11 0 0 Partly Cloudy
    11/10/2016 01:06 PM 77 77 63 6 South Southeast 0 163 10 63 30.08 11 0 0 Partly Cloudy
    One clue on this strange error
    I looked at WeatherXML (attached) and saw it said
    <description>These are estimated conditions. There are no weather stations nearby.</description>
      Looks like you posted from the data user page. That shows what is imported each time you have the weather run.
      The way it works is when the schedule is triggered, it downloads a new xml file and imports the data from the xml file.
      On the location setup page, are you setup to use the Lat and Lon or do you have a station selected in the dropdown?
      Jeff Farmer
      HS 3, HSPhone
        I think it is set to the station
        Jeff thanks for the reply, I have the LAT LONG in there plus the station selected in the drop down below.
          I would suggest either trying a different station or select the Use Lat Lon option. Typically, with the Use Lat Lon option the info is pulled from more than one source and averaged.
          I run mine set on the Lat and Long and have never seen the fluctuation in the values that you are seeing.
          Jeff Farmer
          HS 3, HSPhone
            I will give that a shot
            Thanks, I will set that now!
              See this thread for an update
              http://forums.homeseer.com/showthread.php?p=1275143#post1275143
              Jeff Farmer
              HS 3, HSPhone
