Rain next 24 hours
  • Rain next 24 hours
    This option was present before. Now it's gone.
    Can we have it back?
    Sure! (I was not even aware it was removed)
    I will check later tonight.
      Excellent! I use it for irrigation, and it's a vital part of it.
      I'm asked to speak about "Norways Smartest Home" at a conference, and I thought I'd just take a screenshot of the event running the irrigation, but that didn't work out...
        The plugin should be updated now
        Sent fra min F8331 via Tapatalk
          Perfect! Thanks!
          Now I just wish the plugin didn't stop to find the root device every so often...
            what do you mean "stop to find the root device"?
              There's a root device (named "Do not delete"). Usually the plugin works fine, then suddenly the HStouch screen I have isn't updated anymore. In 95% of the time it's because there's a new "Location-1" root device created instead...
              Oh, and I wish I could pick location and location2 for the device created before they are created.
                Ok
                  I see, all the configuration is stored in the root device. The plugin just asks he homeseer server about the devices and if it's not found or the data in the stored device gets corrupted it assume that no config is there and creates a new root device.
                  I have only experienced this on my test machine when testing different version and installation e.g due to frequent restarts of server. On my production I have never seen this...
                  (And, I will add support for custom location names)
