YR config disappears
  • YR config disappears
    I've had a few incidents where all YR devices suddenly stopped updating, and when checking YR config there are no devices chosen. Seems like it has lost the config. Is this a known bug?
    Running version 3.0.2.23
    this is not a known issue. did something change in the homeseer system when this occurred?
    The YR plugin stores everything in the devices itself and I have i earlier version of HS3 seen that the HS3 system does not report back any devices belonging to the plugin and when this happens the plugin assumes you are setting up a new site for the first time.
    Although I have not experienced this for a very long time now.
    In any case I have been looking at the code for some time to try to optimize it a bit and I have also added the needed api changes. as of mid January the 2.23 version will stop working as api.met.no no longer supports HTTP - Only HTTPS... version 3.2 and newer will use HTTPS.
      I also have trouble with config page.
      Yesterday everything was working. But today nothing was updated.
      I tried to disable plugin and enable it again, then my homeseer server was not responding for several minutes. and the plugin has a warning.
      Also the log is saying :
      Feb-27 08:48:22 Error Initializing plug-in(2): YR Weather Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string) at Scheduler.clsHSPI.CheckInterfaces () [0x00098] in <8378e69e58f94cfaa21253b33447b7f5>:0
      Feb-27 08:48:22 Warning Have not heard from MyHS in over 3 minutes, disconnecting for re-connection.
      Feb-27 08:23:56 Plug-In Finished initializing plug-in YR Weather
      Feb-27 08:19:31 Info
      Plugin YR Weather has connected. IP:127.0.0.1:46334
      Please investigate
      BR
      Clio75
        Please investigate
        BR
        Clio75
        There are little to work on here. The error message is from HS itself. My code has no relation to MyHS so not sure about that error message.
        what happens if you restart Homeseer?
        did anything change last night when this error occured?
        do you by any chance have multiple versions of the plugin running on the server - seen in the task list / top?
        any error message in the Plugin UI when running developer mode?
        or any error in the plugin logfile?
        br
          I have tried to reboot the hole server. But no change in status.
          Missing config page and overload on the server makes homeseer slow response.
          Watching television I found out this when I was checking my server for weather forcast.
          That it did not update anything.
          To the best of knowledge I only have one incident running.
          where can I find this ??
            Are you running this on windows or Linux?
            The log file is located in the Logs folder.
            And make sure that you have the following two lines in the ini file
            [General]
            Debug=True
            LogToFile=True
            Sent fra min G8341 via Tapatalk
              I'm running linux
                Hi,
                I found the INI fil, og inserted the two lines.
                And restarted the plugin. But have NO log file or config page.
                Please advice
                  Hi,
                  Please advice
                  Do you have the Logs folder created in HS root directory?
                    Yes I do,
                    Only Files there are
                    - Homeseerlog.hsd
                    - Previus_Startup-log
                    - Startup.log
                      Did .5 solve the issue or do you still see some problems?
