Changes to the plugin
This is a sticky topic.
    I will post change log to the plugin here:
    version - Change
    3.0.3.10 : Plugin had to change name - New name is MyWeather. When upgrading to this version users have to re-enter the license code and reconfigure the weather devices.
    3.0.3.8 & 3.0.3.9 - Internal testing related to new name
    3.0.3.7 : plugin will no longer use the Textlocation api from met.no as this is being closed down on March 1st 2019
    Hi
    Error message in the plugin 3.0.3.6
    WARNING: Failed getting InterfaceStatus from YR Weather - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    Probably due to the changes in the API as mentioned.
    No update present in updater to 3.0.3.7. Nor in the Beta section.
    Do You have a scheduled release of the new version?
      YR Weather has stoped, it want update any weather devices. Where can I find this 3.0.3.7 version? I only have 3.0.3.6!
        My YR Weather has also stopped.
        Where can I find the updated version??? 3.0.3.7
          Same here. It just stops now...
            Guess it is the same for all of us.
            Mr. Toby, please update us users on the status of the development of the plug-in.
            As it is now, the plug-in doesn't work....
              the 3.01.7 version is now resubmitted to the updater and should be out shortly.
              Sorry about this guys!
                Hi.
                I also get this error Message: have Version: 3.0.3.5
                Tried to update the plugin, but it fails: (Install/Update of package YR Weather failed.), also restarted HS.
                Seems like it stopped working 15.march. Any ideas?
                  Originally posted by espen View Post
                  Hi.
                  to update the plugin you need to disable it first.
