Originally posted by Toby
View Post
Instructions for configring
No, but's a bit busy at the moment.
the config file is under Config in the root folder. here you should find a myWeather ini file. in this file you need to add teh 2 lines if not there already
Code:[General] Debug=True LogToFile=True
I don't even know what ssh means.
Here's a copy of the log after installing and trying to config.
9/03/2020 12:36:00
Legacy-Plugin
weatherXML
Triggers to check: 0
9/03/2020 12:35:50
HomeSeer
Error
Posting back to plugin web page Weather Config: Exception has been thrown by the target of an invocation.-> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x0014d] in :0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00040] in :0
9/03/2020 12:34:19
HomeSeer
Starting Plug-In
Plugin MY Weather started successfully in 7800 milliseconds
