YR Weather HS3 plugin
  • YR Weather HS3 plugin
    The YR Weather HS3 Plugin integrates weather data from YR.no into Homeseer3. YR.no supports Weather data for 1 million places in Norway and 9 million places worldwide
    Key Features:
    User customized device creation through configuration page
    Hour by Hour data for northern Europe
    3 hour interval for the rest of the world
    Day and Night data
    For Norway there is added Radar image and UV forecast data as well as weather warning
    Supports both Norwegian and English language.
    Easy overview through the Meteogram
    Screen shots: see http://srv.rusnes.no/HS/YR/YRWeather.htm
    How To Buy: http://store.homeseer.com/store/YRWe...HS3-P1660.aspx
    Support: put in a request here in this forum
    Can background of meteogram be changed. i need balck BG
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
      I would like to see the same, but the images are produced by yr.no
      I will try to submit a feature request to them.
        I cant install the last update from hs3 updater. Dont have this problem with other plugin.
          Edit
          I got this error
          Install/Update of package YR_Weather failed.
            Originally posted by Mrtiger View Post
            I cant install the last update from hs3 updater. Its saying about that the upload
            Error. Dont have this problem with other plugin.
            Upload error?
            The plugin is not uploading anything.
            If it's download error you mean, I can provide you with a direct link.
              Edit
              I got this error
              Ahh, try disabling the plugin first.
                Sorry, i got this error
                  Thanks, it did install it now😃
                    Is it possible to install this on the HomeTroller Zee?
                    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
                      I do not have a zee so I have never tried to run it on Linux.
                      If you are willing to try, and know how to manually install plugins on it, then I'm willing to adjust the code to get the file paths correct on Linux and do other adjustments if needed.
                        I will set myself into how to install on the Zee.
                        Don't know where to start. But im willing to work on this and try this
