This device needs to die
  • This device needs to die
    I'm talking about this one:
    1. It does not provide any useful information.
    2. It reappears (even if others exists) with the wrong Floor and Room. Like this:
    Last week I had 6 or 7 devices like this.
    There's something called "credit when credit is due", but come on...
    So did the devices credited serve an adjuvant (mix of terminology) automation purpose or are they just nice to look at Magnus?
    Has an automation poltergiest (IC-apparition) taken over your automation databases?
    Do you do as the computer tells you what to do or do you tell the computer what to do?
    Last week updated one plugin. It recreated every device variable (> 100 credits).
    The new variables showed accurate statuses; the old variables did not.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
      Very philosophical, Pete.
      I tell the computer what do do when it is my place to tell it what to do. In this case, it does what Toby tells it what to do....
        Yeah; here disabled the plugin, deleted all of the variables (extra credits) / events associated with it, enabled the plugin and let it recreate all of the device variables and I manually re-entered the events.
        It was a PITA to do and unexpected (well expected unexpected expected then unexpected).
        We should have some sort of Homeseer documentation notes about this.
        Years ago while in school we had a set of notes (technical documentation) that was very popular called "no fahkin sabee notes" later shortened to "fahkin sabee notes" (don't know who came up with this name though).
        For a while these notes were said to be a rumor; but if you had them in your possession and understood them; that was all you needed. (so there was a search the notes for a bit; similar to one of Jason and the Argonauts looking for the Golden Fleece). I did find the notes. The paper at the time (with typed and hand written adds) wasn't even watermarked and kept by a select few (old wise men - elders). You couldn't tell though what the notes were for though until you read them.
        - Pete
        Auto mator
        HS4 Lite -
          looks like the change of room/floor has some effect here - I will look at this and change it.
          according to the terms of use of Yr.no weather data this exact line and link needs to be present.
          (although only once - I will have a look at this and release a fix.
            Hmmm... I was a bit too quick in my response here. I'm not able to reproduce this error. Are there any specific action that is done to trigger this?
            Looking at the code it should only create a new device if HS3 db does not return a device, owned by the plugin with the PED object named Credit.
            What version of HS3 are you using?
              It's been like this with all versions of HS3 I've used while using the plugin. The latest is .152. As far as I know there's nothing that I do to make this happen. It seems very weird that a non-changing system should give this behaviour, but here we are...
              Yes, I know YRs terms of service requires you to have that link present, but it does not specify WHERE (or to be more specific, that it need to be present in an actual device in HomeSeer).
              Can't you just get rid of the device, and put the link on the Config and Status pages. You could even make it a menu item in the plugin menu.
                It specifies that it needs to be present clearly in relation to the weather forecast.
                in any case, please try the latest version available in the updater to see if this solves anything.
                  So... on the Weather Status page it is, then.
                  Devices can be hidden and deleted (I guess that's why it keeps reappearing), and I can choose not to show it at all in my own custom pages and HStouch. And in any case, I would assume that most users using this plugin would know that the data from a plugin named "YR Weather" does come from yr.no.
                  No update found yet, but I'll keep checking. Thanks!
