Current Radarimage
  • Current Radarimage
    Hi
    I do not get an image for the "Current Radarimage". It does not show on my screens or in the device. In the device I only get the typical "cannot find image"-square. When looking into the images-folder on my HS-server, there is no radarimages there even if Radar Image are checked and location selected.
    For what area are you requesting the radar image?
    Sent fra min E6653 via Tapatalk
      I try to get south east norway.
      Radarimage is checked and i have selected southeast_norway.
      EDIT:
      This just appeared in my log:
      feb-29 17:24:52 Warning Image file does not exist, returning blank image: D:\Automation\HS3\html\images/YR/images/radar_1_2016022917.gif
        Problem solved. Download the latest version and you should get the image again.
        For some reason I missed an update in the API seting the old API verson invalid from 15/2 2016.
          When I download latest version I get:
          Install/Update of package YR_Weather failed.
          Any log I can look into?
            Please disable the plugin first, then try again.
            I'm not sure why HS3 keeps lock on some of the files when updating. But disable - update - enable works.
            Br
            Toby
              Thanks. That worked. Now its just waiting for a new update and verify that the radarimage is downloaded. Thanks for quick support
