Version 3.0.2.15 bug in InterfaceStatus
  • Version 3.0.2.15 bug in InterfaceStatus
    The plugin seems to be working like it should, but the Plugin -> Manage page reports an error:
    ... and yes, I've tried starting and stopping it.
    It's probably 2 instances of the plugin running - please check this.
    in any case - please update to 3.0.2.16.
      No, that wasn't the case. I checked.
      But I'll check 3.0.2.16.
        There is no change to to plugin that should cause any changes to the InterfaceStatus.
        Any luck with the latest version?
          Yes, that works.
          EDIT: Thanks (for whatever you did).
            This problem is occurring on several systems where this plugin is installed. But after some time the error goes away. So not sure why this happens.
            Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
