RFXCOM support models
This is a sticky topic.
    Here are the supported RFXCOM models for BLRF. These are the new model units from RFXCOM.
    RFXrec433
    RFXtrx315
    Note: The old models are not supported in the plug-in.
    If a user with an RFXtrx433 would like to use the RFXtrx433 in the plug-in, you will have to flash the RFXtrx433 with the RFXrec433 firmware. This firmware is available on the RFXCOM download page. The RFXtrx433 operates than as an RFXrec433.
    The RFXtrx315 is a transceiver and can be configured by your plug-in to 310MHz or 315MHz mode. In 310MHz mode, the RFXtrx315 can receive US X10 sensors. In 315MHz mode, it can receive US Visonic PowerCode sensors.
    I will have to add an option to the plugin to change the mode of the RFXtrx315 unit.
    The RFXrec433 and the RFXtrx315 models look like these
    RFXrec433 http://store.homeseer.com/store/RFXC...P1199C240.aspx
    RFXrec433 http://www.rfxcom.com/store/Receivers/12113
    RFXtrx315 http://www.rfxcom.com/store/Transceivers/12102
    Cheers,
    Bob
    Hi,
    I have one of these on its way:
    RFXtrx433 USB 433.92MHz Transceiver
    is it supported by your plugin?
    Also does the w800usb work?
    thanks
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
      Bump, also have this on order to support among other things RGB lights. Will the plugin support?
      HS3 Prod - Win10 - DSC - HVAC-GC-TBZ48 x3 - CurrentCost - BLRadar - RFXCOM/FRXTRX433 -ADIO - HSTOUCH - BLUPS - AB8SS - SONOS - Alexa - 1 wire - BlueIris -MyQ
        Older model Rfxcom
        Hi I have a older model 433 receiver usb working fine on homeseer 2 with rfxcom plugin.
        I have upgrade to HS3 and rfxcom plugin V3.
        It s work if I define interface in receiver panel: but detect only temp on oregon sensor (no humidity). Security X10 are ok.
        RFXCOM 24 (RecRxChar) receiver #1 successfully initialized to 32 bit mode
        When I m trying to setup on RFXtrx/RFXrec panel and get error:
        oct.-28 08:23:42 RFXCOM 24 (HSEvent) Transceiver1 deleted from the plug-in
        oct.-28 08:23:38 RFXCOM 24 (CheckTransceivers) transceiver #1 info: resynced
        oct.-28 08:23:38 RFXCOM Error: 24 (CheckTransceivers) error returned from RecTRXChar
          If you are using the RFXCom plugin, then you should probably post this question there http://board.homeseer.com/forumdisplay.php?f=899. This section is for the BLRF Plugin (which does support some RFXCom hardware).
          Cheers
          Al
          HS 4.2.8.0: 2134 Devices 1252 Events
          Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
