Hi Blade.
Just a bug report, and it could be my own system but when i tried to enable the plugin with my W800RF receiver it reported: EXCEPTION from HRESULT 0x800A1F42
This appears to be as a result of having a com port 10 or greater which has a slightly different naming scheme (i believe).
It was an easy fix, I just moved the ports around however thought you might like to be aware of it.
Cheers
-- SOLVED, all fixed up by lowering com ports
Cheers
