Need help creating devices for X10 RFmotion sensors
    I am having trouble figuring out how to create devices for the standard x10 motion sensors using this plug in. it triggers my events when rf is received but I would like to create devices so that I can add these to BLSecurity and BLRadar is this possible
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    Manually create the device from the Device Management screen. Then on the Device Configuration screen set the House Code using the drop downs. At least that's how I did it and it works fine.
      I tried that but the device value never changes on the virtual device how are you setting this up
      cheers ken
        I got it thanks for the help
        Sent from my EVO using Tapatalk
          Same problem here. How'd you get i working?
            I installed the CM15A plugin and then just configure the devices under the x10 tab and it will change value with the sensors that have the same address
            Cheers Ken
